Reading from multiple RFID-modules at the same time
Hello everyone,
I recently bought 2 RFID-modules witch I connected to the arduino DUE.
The RFID-modules are from parallax: RFID-read/write module LINK
I have managed to let them read but the only problem is, when one RFID-module is reading , the other stop reading until his reading function is called again then the other stops reading and so on …
I have tried to use multi threading but that didn’t work , also I have tried interrupts but when the RFID module is reading he constantly gets information back also if no card is scanned.
So i’m hoping anyone could help me, letting the 2 RFID modules read at the same time.
If you need more information just ask.
Here is my code
(Don’t mind the led and bits to hex part)
// rx Serial ingang (connecteer aan de RFID's SOUT pin)
// tx Serial uitgang (connecteer aan de RFID's SIN pin)
#define BUFSIZE    12  // Size of receive buffer (in bytes) for incoming data from the RFID R/W Module (this should be adjusted to be larger than the expected response)
// RFID R/W Module Commands
// Number of bytes returned in ()
#define RFID_Read         0x01	  // Read data from specified address, valid locations 1 to 33 (5)
// Memory map/address locations for EM4x50 tag
#define ADDR_Serial	  32	  // Device Serial Number
// Status/error return codes
#define ERR_OK		  0x01	  // No errors
int ledPinGroenInside = 2; // pin binnen Groene led
int ledPinRoodInside = 3; // pin binnen Rode led
int ledPinGroenOutside = 4; // pin buiten Groene led
int ledPinRoodOutside = 5; // pin buiten Rode led
int DeurSlot = 7; // pin deurslot
  //Instellingen ledjes
  pinMode(ledPinGroenInside,OUTPUT);
  digitalWrite(ledPinGroenInside,LOW);
  pinMode(ledPinRoodInside,OUTPUT);
  digitalWrite(ledPinRoodInside,LOW);
  pinMode(ledPinGroenOutside,OUTPUT);
  digitalWrite(ledPinGroenOutside,LOW);
  pinMode(ledPinRoodOutside,OUTPUT);
  digitalWrite(ledPinRoodOutside,LOW);
  //Instellingen Deurslot
  pinMode(DeurSlot,OUTPUT);
  digitalWrite(DeurSlot,LOW);
  // Arduino serieële monitor instellen
  while (!Serial);   // Wachten tot hij klaar is
  Serial.println("Scan je kaart in 1 van de 2 RFID modules");
  // set the baud rate for the SoftwareSerial port
  Serial1.begin(9600);
  Serial2.begin(9600);
  Serial.flush();   // wait for all bytes to be transmitted to the Serial Monitor
  uint8_t rfidData[BUFSIZE];  // Buffer voor inkomende data
  ledControle();
  //RFID BINNEN
  rfidRead1(rfidData, ADDR_Serial);
  ledControle();
  //RFID BUITEN
  rfidRead2(rfidData, ADDR_Serial);
//Ledjes controle
void ledControle()
  if (Serial.available() > 0) {
  //int Controle = Serial.read() - '0'; // deduct ascii Controleue of '0' to find numeric Controleue of sent number
  char Controle = Serial.read();
  if (Controle == '1'){
   //Serial.println("Deurslot openen voor 3 seconden");
   digitalWrite(DeurSlot , HIGH);
   delay (3000);
   digitalWrite(DeurSlot , LOW);
  else if (Controle == '2'){
   //Serial.println("Led groen binnen gaat voor 3 seconden aan");
   digitalWrite(ledPinGroenInside , HIGH);
   delay (3000);
   digitalWrite(ledPinGroenInside , LOW);
  else if (Controle == '3'){
  // Serial.println("Led rood binnen gaat voor 3 seconden aan");
   digitalWrite(ledPinRoodInside , HIGH);
   delay (3000);
   digitalWrite(ledPinRoodInside , LOW);
  else if (Controle == '4'){
  // Serial.println("Led groen buiten gaat voor 3 seconden aan");
   digitalWrite(ledPinGroenOutside , HIGH);
   delay (3000);
   digitalWrite(ledPinGroenOutside , LOW);
  else if (Controle == '5'){
  // Serial.println("Led rood buiten gaat voor 3 seconden aan");
   digitalWrite(ledPinRoodOutside , HIGH);
   delay (3000);
   digitalWrite(ledPinRoodOutside , LOW);
  //deurslot
  else if (Controle == '7'){
  // Serial.println("Deurslot openen");
   delay (1000);
  else if (Controle == '8'){
  // Serial.println("Deurslot sluiten");
   delay (1000);
//RFID BINNEN (1)
char rfidRead1(uint8_t *data, uint8_t address)
  char offset;  // offset1 into buffer
  rfidFlush1();  // empties any buffered incoming serial data
  Serial1.print("!RW");       // header
  Serial1.write(RFID_Read);   // command
  Serial1.write(address);     // address
  while (Serial1.available() != 5);  // wait until data is received from RFID module
  if (Serial1.read() == ERR_OK)  // if our status byte is OK
    for (offset = 0; offset < 4; offset++)
      data[offset] = Serial1.read();  // get the remaining data
      Serial.print("0-RFID Binnen: ");
      PrintHex(data, 4);   // De rfidData1 string moet nu het serienummer van de tag bevatten, en geeft het weer op de seriêle monitor
      Serial.flush();
    return 0; // return good
  return -1; // return error
void rfidFlush1()  // Empties any buffered incoming serial data
    while (Serial1.available() > 0)
      Serial1.read();
//RFID BUITEN
char rfidRead2(uint8_t *data, uint8_t address)
  char offset;  // offset2 into buffer
  rfidFlush2();  // empties any buffered incoming serial data
  Serial2.print("!RW");       // header
  Serial2.write(RFID_Read);   // command
  Serial2.write(address);     // address
  while (Serial2.available() != 5);  // wait until data is received from RFID module
  if (Serial2.read() == ERR_OK)  // if our status byte is OK
      data[offset] = Serial2.read();  // get the remaining data
       Serial.print("1-RFID Buiten: ");
       Serial.flush();
void rfidFlush2()  // Empties any buffered incoming serial data
    while (Serial2.available() > 0)
      Serial2.read();
// prints 8-bit data in hex
void PrintHex(uint8_t *data, uint8_t length)
  char tmp[length*2+1];
  byte first ;
  int j=0;
  for (uint8_t i=0; i<length; i++)
    first = (data[i] >> 4) | 48;
    if (first > 57) tmp[j] = first + (byte)39;
    else tmp[j] = first ;
    j++;
    first = (data[i] & 0x0F) | 48;
    else tmp[j] = first;
    j++;
  tmp[length*2] = 0;
  Serial.print(tmp);
What do you think this does if 6 chars are received?while (Serial1.available() != 5);
Even though it’s very very unlikely, it is theoretically possible to get more than 5. Always write this kind of test with a “>”, “<”, “>=” or “<=”.
Your rfidRead#() functions are sending stuff to Serial as well as adding a one-second delay. The description of the function should match its action. If it’s called “read” then it shouldn’t ever be writing to another output (and then waiting more than a second for that output to go out.)
These comments are wrong. Always update your comments when you add new functions:
And then review the comments again before posting to the forum. What pins are the modules actually connected to?
OK, let’s look at the loop…
  ledControle();
  //RFID BINNEN
  ledControle();
  //RFID BUITEN
Is this the code which doesn’t work or does work? It looks like you’ve just written test code because it never uses the contents of the data buffer.
