Reading from (sd card), and analyzing them
Hi :slight_smile:
I have a set of readings inside (sd card) this way:
22,2451.541
44,412.1
77,4452
11,654121.2114
I want to read from (sd) a line line in order from one line to the last line, each time the value of the read line is placed in variable (a)
Each line is analyzed in this way:
a=11,654121.2114;
f=11;
h=654121.2114;
//While keeping the figures as they are h=654121.2114
Thank you...
You can use myFile.parseInt() and myFile.parseFloat() with the SD library.
a=11,654121.2114;
This most likely won't work.
meltDown:
I will be experimenting, thank you for this information
zwieblum:
a=11,654121.2114;
what is the reason ?
aradiblawi:
Well "a" would be a variable, say an int or a float, able to hold one value. Seems you expect it to hold two...
meltDown:
Okay ,
If we write data in (sd) this way:
"11,654121.2114"
It is then stored inside a variable of type string
String a;
a="11,654121.2114";
Is this method correct?
