Reading from Serial returns question marks
Hello everyone, i am trying to communicate with another device using an Arduino Nano. I have connected the device to the software serial ports, and i use the hardware serial ports to print the output of the serial port. I use 115200 baudrate everywhere, i can read most of the output of the device correctly, but at points it prints something like that: " Creating 1 MTD partitions on "P⸮⸮MTS⸮⸮ՊT⸮⸮Uɥ⸮⸮⸮2⸮⸮͡⸮⸮j ". Any idea what could be causing that? Since it displays most of the output properly?
#include <SoftwareSerial.h>
SoftwareSerial mySerial(4, 5); // RX, TX
  // set the data rate for the SoftwareSerial port
  mySerial.begin(115200);
void loop() { // run over and over
  if (mySerial.available()) {
    Serial.write(mySerial.read());
  if (Serial.available()) {
    mySerial.write(Serial.read());
115200 baud is too fast for SoftwareSerial
Hm I have an arduino Mega lying around, i will give it a try using both hardware serials!
Thank you for your input!
That sounds like a much better idea
Ok so I used the mega and it works! Thank you very much!
rozakos:
If the device name has Unicode characters and you are displaying them as ASCII, that could cause them to appear wrong. Serial.read() returns an int. Perhaps Serial.write() is sending both bytes of that int. Try casting the int to a char before writing it:
    Serial.write((char)mySerial.read());
    mySerial.write((char)Serial.read());
