Reading from the NXT Light Sensor
Hi there,
I have been having trouble interfacing with the Lego NXT Light sensor: the analogRead() from pin1 of the NXT cable always returns either a 0 or 1, with the occasional 2 or 3. I have connected the pins from the sensor in the following way:
pin1 - Arduino analog pin A0 (white)
pin2 - GND (red)
pin3 - GND (black)
pin4 - +5V (green)
pin5 - +5V (blue)
pin6 - NC (yellow)
Here is my code. I have a slight suspicion that the sensor needs a certain delay between readings, but after scouring the internet and trawling through the Lego NXT documentation, I found nothing. It probably does not help that I am not an advanced user!
Any help would be greatly appreciated!
const int inpin = A0;
  delay(3);
  int val = analogRead(inpin);
  Serial.println(val);
Schematic of the light sensor:
http://www.legoengineering.com/knowledgemanager/getattachment.php?data=MTU0fEFwcGVuZGl4IDMtTEVHTyBNSU5EU1RPUk1TIE5YVCBMaWdodCBTZW5zb3IgaGFyZHdhcmUgc2NoZW1hdGljLnBkZg%3D%3D
Looks like an open-collector output which means that it requires a pull-up resistor.
It appears that it MIGHT be an oscillator that generates a PWM signal on the 'analog' line.
Pin 5 appears to control the red LED (Wikipedia says pin 5 is YELLOW, not BLUE)
johnwasser:
Thank you very much. Putting a 10K? pull-up resistor in there did solve the problem.
You are correct, it was indeed yellow, not blue. Sorry for the mistake.
May I ask, how does connecting a pull-up resistor to the collector of a transistor solve the problem? Would it be due to the voltage drop across it, creating the output 'signal'?
Yes, all the sensor is is a variable resistor. By using a pull up you cause current to flow that turns the changing resistance into a changing voltage.
Many thanks. I suspected as much.
