Hi guys, I'm using encoder 2000 ppr. it is stepping pack with driver and when i tested this encoder with arduino uno R3, it can counted accurately with my hand in low speed. but it can not receive the number of encoder when i used high speed and start to test with the motor. So, in this step, the problem is about the frequency from the output of encoder and the input of digital input in encoder are not same, isn't it?
suradeer:
Well, basically, i want the encoder to get more than 2000 pulse per second. 2000 ppr is for one cycle. Furthermore, i use Nointerrupt of the encoder
"more than 2000" is not much help. Do you mean 2005, or 25,000? Successful computer programming requires precision.
And if you want to detect a high pulse rate why (oh why) are you not using interrupts.
The link in your Original Post require a person to register to access the documents and the code. I presume you have done that. Can you attach the documents here?
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Also specs/data for motor and encoder.
Robin2:
...R
The document is here https://www.semicon.com.pl/files/?id_plik=402 my model is PB3d003m200. I use around 18000 ppr. In my project, i do the goalkeeper and it translate in x-axis. So, could u have some guideline or suggestions?
Thanks.. Tom...
Thank you for ur advice. I do not write the citcuit but i hav only the block diagram.
