I want to read two Honeywell HSC Sensors over SPI. One is a 1.6Bar absolute Sensor (HSCMRNN1.6BASA3) and the other a 60mBar differential Sensor (HSCDRRN060MDSA3).
SS Connected to Digital Out 3 (Absolute 1.6Bar Sensor) and Digital Out 2 (relative 60mBar).
Here is my code:
#include <SPI.h>
uint8_t chipSelectPin1 = 3;
uint8_t chipSelectPin2 = 2;
SPI.begin();
pinMode(chipSelectPin1, OUTPUT);
digitalWrite(chipSelectPin1, HIGH);
pinMode(chipSelectPin2, OUTPUT);
digitalWrite(chipSelectPin2, HIGH);
float val1 = (1600 * ((float)readSensor(chipSelectPin1) - 1638) / 13107);
Serial.print("PRESS1 = "); Serial.println(val1);
float val2 = (40 * ((float)readSensor(chipSelectPin2) - 1638) / 4369) + 60;
Serial.print("PRESS2 = "); Serial.println(val2);
int16_t readSensor (uint8_t selectPin) {
SPI.beginTransaction(SPISettings(700000, MSBFIRST, SPI_MODE1)); // Set to 700kHz, MSB and MODE1
digitalWrite(selectPin, LOW); //pull Chipselect Pin to Low
int inByte_1 = SPI.transfer(0x00); // Read first Byte of Pressure
int inByte_2 = SPI.transfer(0x00); // Read second Byte of Pressure
int inByte_3 = SPI.transfer(0x00); // Read first Byte of Temperature
int inByte_4 = SPI.transfer(0x00); // Read second Byte of Temperature
digitalWrite(selectPin, HIGH); //pull Chipselect Pin to High
SPI.endTransaction(); //end SPI Transaction
Serial.print("Chipselect = "); Serial.print(selectPin, DEC); Serial.print(" ");
Serial.print("Byte_1 = "); Serial.print(inByte_1, DEC); Serial.print(" ");
Serial.print("Byte_2 = "); Serial.print(inByte_2, DEC); Serial.print(" ");
Serial.print("Byte_3 = "); Serial.print(inByte_3, DEC); Serial.print(" ");
Serial.print("Byte_4 = "); Serial.print(inByte_4, DEC); Serial.print(" ");
int16_t pressure_dig = inByte_1 << 8 | inByte_2;
inByte_3 = inByte_3 << 3; //Shift first Temperature byte 3 left
float realTemp = ((float)inByte_3 * 200 / 2047) - 50; //Convert Digital value to °C
Serial.print("Temp[C]= "); Serial.print(realTemp); Serial.print(" ");
return pressure_dig; //return digital Pressure Value
Somehow, I dont get the correct values:
Chipselect = 2 Byte_1 = 255 Byte_2 = 255 Byte_3 = 255 Byte_4 = 255 Temp[C]= 149.32 PRESS2 = 44.99
Chipselect = 3 Byte_1 = 31 Byte_2 = 255 Byte_3 = 88 Byte_4 = 111 Temp[C]= 18.78 PRESS1 = 799.94
Chipselect = 3 Byte_1 = 31 Byte_2 = 253 Byte_3 = 88 Byte_4 = 111 Temp[C]= 18.78 PRESS1 = 799.69
A weather station in this area with approx 45.6m height difference gives me a value of 1022mBar.... not 799 as indicated by the absolute pressure Sensor.
The second Sensor should give me 0 since nothing is connected to the ports.
The temperature is read in the same way on both sensor but I receive two different values (although 18.78 should be correct).
Any ideas?
Thanks
Here is the Datasheet
And here is a application Datasheet
