Reading in a push button inside Switch statement within another Switch statement
So i'm trying to read in a push button in a switch statement within another switch statement. I have used interrupts to arrive at my main Switch statement case (works fine). But how do i use the same push button to check another switch statement within the case i'm already in ?
Here's a the code i need help with.
void loop(){
    switch (clickCount)
        case 0: // READY state
        case 1: // 1 click
        case 2: // 2 click
        case 3: // 3 click. I NEED HELP HERE
            // in here i need to use the same button that has been interrupted to read in another switch statement.
           // when done i need the interrupt to go back to the original interrupt function
        case 4: // 4 click
        case 5: break; // 5 click
        case 6: // 6 click
        default: // clicks > 6 [also do nothing] for cases more than 6 for example
    // there is nothing to stop you from putting another switch/case (nesting)
    // right here - presumably with a different switch parameter.
    // https://www.tutorialspoint.com/cprogramming/nested_switch_statements_in_c.htm
This does not make sense. Why are you using an interrupt to read a switch pin? That is most likely the wrong thing to be doing.
That is NEVER going to happen.
