Reading in Large Numbers from Serial
For the project I am currently working on I need to read in a group of large numbers and then store those numbers into an array. The numbers are separated by commas and the numbers range from 1-16777215.
An example string that would be coming across the Serial connection is: “255,1677215,55555,90000,1672166”.
Does anyone know the best way to do this using Serial.read() or if there is a better way to read in and store these numbers since they span anywhere from 1-3 bytes?
Thanks!
Store the characters in a buffer until you see a ',' then nul terminate the buffer and call strtoul() on it to convert it to an unsigned long. You can then take it from there.
One character at a time.
Presumably, you need these as numbers, not strings, so Serial.parseInt() is an alternative to Serial.read() and storing and parsing the data yourself.
