Hello, everybody. Once again, I'm here to ask for some help.
I'm trying to read integer numbers from serial monitor, in order to control a stepper motor. For example, I'd like to enter '36' in order to make the motor rotate 36 degrees. However, I can't deal with the fact that the serial reads a byte at a time. When I need to use strings, I usually manage to overcome this problem. I am not finding a solution in this case, though. Could anyone suggest something? Thanks a lot.
