Hello all,
I'm currently working on a project to develop an RFID reader that is able to detect and out the unique identifier of ISO 14443B cards. The reader I am using is an RDM8800 connected to a ITEAD Studio FOCA v2.0 board. This allows the code to sent to the reader using Arduino 1.0.6
As of now, I am able to detect and obtain the unique identification numbers of such cards operating on F7 81 85 Protocol, but not so for those with 77 81 85 Protocol. Can I get some advice on whether it is possible to modify the code/circuit to read those with the latter protocol?
I've also attached the datasheets for the components that I am using for the circuit. Any help on this is greatly appreciated.
The code I am using is:
/******************** RDM8800 *************************
This vesion source code of RDM8800 firmware reads Singapore's EZLink cards.
They use 13.56MHZ RFID Tag type ISO 14443 Type B[1] / CEPAS protocol.
When a card is detected it returns as a comma seperated list of text fields.
They are the card number, balance, number of days since 1995-01-01 to expire
and number of days since 1995-01-01 created.
So for example:
Presenting a card will return:
1000130019390060,8.38,9107,6915
Which can be broken up into the following comma seperated fields:
Number: 1000130019390060
Balance: 8.38
Expire days: 9107
Created days: 6915
#include <PN532Lib.h>
#include <SPI.h>
#define PN532_CS 10
//LED indicator
const int LED = 6;
// set PN532 instance
PN532Lib nfc(PN532_CS);
uint8_t cardDataIn[128];
uint8_t cardDataOut[] = {
0x01, // target number (always 1)
0x90, // command class
0x32, // INS - read purse
0x03, // purse #3
0x00, // param 1
0x00, // param 2
0x00, // LC
0x00 // ??
// setup serial at 9600 baud
// startup the nfc card reader
nfc.begin();
nfc.SAMConfig();
uint32_t versiondata = nfc.getFirmwareVersion();
Serial.print(versiondata);
if (! versiondata) {
Serial.print("Didn't find PN53x board");
while (1); // halt
pinMode(LED,OUTPUT);
digitalWrite(LED,HIGH);
delay(2000);
digitalWrite(LED,LOW);
// look for EzLink cards
uint32_t id = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443B, PN532_CARDTYPEB);
// if random tag id number then we have a card
if (id != 0) {
Serial.print("Card detected");
// now request the card data
if ( nfc.dataExchange(cardDataOut, sizeof(cardDataOut), cardDataIn, sizeof(cardDataIn)) ) {
// if card data found set the LED to on
// send out the card number
uint8_t i;
for ( i = 0; i < 8; i ++ ) {
Serial.print((cardDataIn[8 + i] >> 4) & 0x0F, HEX);
Serial.print(cardDataIn[8 + i] & 0x0F, HEX);
// send out the balance
double balance = (cardDataIn[2] << 16 ) | (cardDataIn[3] << 8 ) | (cardDataIn[4] );
Serial.print(",");
Serial.print(balance / 100);
// send out the expired day count from 1995
uint32_t expireDays = (cardDataIn[24] << 8 ) | (cardDataIn[25]);
Serial.print(",");
Serial.print(expireDays);
// send out the created days
uint32_t createDays = (cardDataIn[26] << 8 ) | (cardDataIn[27]);
Serial.print(",");
Serial.print(createDays);
// send the end or record cr/lf
Serial.println(" ");
// wait a bit for the LED
delay(20);
// off LED
// loop delay before the next read attempt
delay(100);
Foca.pdf (388 KB)
RDM8800-Itead Studio.pdf (332 KB)
