Hello everyone, thanks for taking the time to read this, I really appreciate it.
So I have 3 7 segment display that displays outside, what i want to do is read into the Arduino
It is common anode
pin A,B,C,D,E,F,G set pin 2,3,4,5,6,7,8 arduino
3 pin digit set 20,21,19
this is my code.
volatile int flag1 = HIGH;
int A = 2;
int B = 3;
int c = 4;
int D = 5;
int E = 6;
int F = 7;
int G = 8;
when i open serial monitor, it's wrong when i change the number of machine.it alway set 8 number...i mean pin A,B,C,D,E,F,G is "1".
how can i fix it....
septillion:
You might want to do something with the first part of my reply as well. Otherwise I don't expect a lot of answers...
i apologize if i do something wrong, i'm not good at english, this is 1st i use forum on web.
1 ditgit(1 led) i set pin 20 to set attachinterupt(3) for board arduino mega 2560, is this right?
Are the following statements correct in respect of your post?
1. You have 3-digit CA(common anode)-type 7-segment multiplexed display unit. Let us designate them from left as DP0, DP1, and DP2
2. The segments A, B, C, D, E, F, and G are being driven by DPin-2,3,4,5,6,7, and 8 of Arduino MEGA. You are not driving the dot/point (.) of the display devices?
3. The anode terminals CA0 (common anode pin of DP0), CA1, CA2 of the display devices are being driven by DPin- 20,21, and 19.
4. On the basis of the above information, can the following diagram be presented for your display unit?
5. Now, my questions? (a) Do you have any plan to install current limiting resistors at the CA-pin of the display devices? (b) What is the purpose of this display unit? What kind of information are you going to show using this display unit? (c) Do you know how much current a digital IO pin of the MEGA can deliver? Assume that it is 20 mA and all the segments of DP0 will be ON. A segment normally draws 10-15 mA current to give an acceptable level of brightness; if so, there is a requirement of 7x15 = 105 mA current for all the 7-segments of a display device which an IO pin is unable to delver. In this case, do you have any plan to derive the CA-pins/segment-pins using external current drivers?
I think you will need to use a 'scope to understand the timing of the cathode and anode signals. Could be that the anode goes high before the cathodes go low, for example.
However, I don't think your method of setting a flag in the interrupt will work correctly. You may need to read each of the inputs, and save their values, in the interrupt. Otherwise, by the time loop() has checked the flag and captured the inputs, the anode may have gone low again.
Also, the cathode drivers may be open-collector, so even if you read the inputs at the correct time, they may be floating.
I change digitalRead => analogRead and change pinMode(A, INPUT_PULLUP),i connect resistor 1k pin A to 3,3v.it's ok. The number's analog about 800 when led pin A on.i try connect res 1k to all pin B,C,D,E,F,G is go crazy...analog number is change to much...i dont know why:frowning:
Read and implement what PaulRB told you in reply #9.
That is what you need to do.
Your code as it is will only read one digit of your three even when you make these changes.
Grumpy,i dont know how to check capture,
I change
Void setup(){
Attachinterupt(3,capture,rising)}
Void loop(){
If (flag==HIGH){
Flag=LOW
If (state_a<800 && state_b<800......)
One=0
Serial.println(one)
I read 1 led first,if ok then i read 3 led,thats why only have 1 attachinterupt
I declare volatile int sate_a
Volatile int stae_b
But number of analog still change
Thanks.
At first glance that looks not so bad.
However, you are using analogRead, instead of digitalRead and the decoding - segments to numbers is a bit "pants" ( British slang for not very good ). Also after the first "if" statement in the loop function add a:-
noInterrupts();
call and before the Serial.Print statement add a
interrupts();
call.
Finally delete the } after the last if(State_A<800 &&..... line and place a } at the very end of the loop function.
Because the analogRead takes 0.1mS to process then for the 7 you use in the interrupt service routine you will use up 0.7mS. This could well be slower than that board is refreshing the digits on the display.
So try this code and see if you are getting a consistent reading from just one segment.
volatile int flag = HIGH;
byte A =A0;
byte ONE = 20;
volatile int State_A=0;
pinMode(ONE, INPUT_PULLUP);
pinMode(A, INPUT_PULLUP);
attachInterrupt(3,capture1,RISING);
if (flag==HIGH){
noInterrupts();
flag=LOW;
Serial.print("Segment a:");
if(State_A > 800) Serial.println("Off");
else Serial.println("On");
interrupts();
delay(200);
void capture1()
{ flag=HIGH;
State_A = analogRead(A);
Now I want to see a picture of how you have wired it up, so showing the board and the wires into the Arduino.
Well not quite what I was asking for. I wanted to check that the ground on your device is connected to the ground on the Arduino. And I can't honestly say I am convinced that it is.
