Hello
I have used the code provided by Sparkfun.
I added my code to it. The problem is that when I added my code and wanted to save the results of downforce and drag force, it did not accept as it showed a declaration error. What I tried to do is that I added the load cells part to the byte part but then it stopped creating files completely, although there was no error.
So how can I save my load cell readings to the SD card the same way the GPS data is being stored?
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include <TinyGPS++.h>
long lastTime = 0;
long seconds = 0;
long minutes = 0;
long hours = 0;
int pinCS = 10;
// Create an LCD object. (Parameters)
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Sets the LCD I2C address
const float referenceVolts = 5;
const int FrontLoadCell = A3;
const int MidLoadCell = A1;
const int RearLoadCell = A2;
#define ARDUINO_USD_CS 10
#define LOG_FILE_PREFIX "gpslog"
#define MAX_LOG_FILES 100
#define LOG_FILE_SUFFIX "csv"
char logFileName[13];
#define LOG_COLUMN_COUNT 6
char * log_col_names[LOG_COLUMN_COUNT] = {
"downforce", "dragforce","altitude", "speed", "date", "time"
}; // log_col_names is printed at the top of the file.
// Log Rate Control //
#define LOG_RATE 5000 // Log every 5 seconds
unsigned long lastLog = 0; // Global var to keep of last time we logged
TinyGPSPlus tinyGPS;
#define GPS_BAUD 9600
#define ARDUINO_GPS_RX 9
#define ARDUINO_GPS_TX 8
SoftwareSerial ssGPS(ARDUINO_GPS_TX, ARDUINO_GPS_RX); // Create a SoftwareSerial
#define gpsPort ssGPS // Alternatively, use Serial1 on the Leonardo
#define SerialMonitor Serial
lcd.begin(20, 4);
lcd.setCursor(0,0);
lcd.print("Downforce =");
lcd.setCursor(0,1);
lcd.print("Dragforce =");
lcd.setCursor(0,2);
lcd.print("Speed =");
lcd.setCursor(0,3);
lcd.print("Time=");
SerialMonitor.begin(9600);
gpsPort.begin(GPS_BAUD);
SerialMonitor.println("Setting up SD card.");
if (!SD.begin(ARDUINO_USD_CS))
SerialMonitor.println("Error initializing SD card.");
updateFileName();
printHeader();
if(millis()-lastTime > 1000)
seconds++;
lastTime = millis();
if(seconds > 60){
minutes++;
seconds = 0;
if(minutes > 60){
hours++;
minutes = 0;
// wait a few seconds between measurements.
delay(1000); // delay 1 second
float flc = analogRead(FrontLoadCell); // reads the value from the sensor
float FLCvolts = ((flc / 1023.0) * referenceVolts)*26.082; // calculates the ratio
float rlc = analogRead(RearLoadCell); // reads the value from the sensor
float RLCvolts = ((rlc / 1023.0) * referenceVolts)*34.014; // calculates the ratio
float mlc = analogRead(MidLoadCell); // reads the value from the sensor
float MLCvolts = ((mlc / 1023.0) * referenceVolts)*17; // calculates the ratio
float downforce = FLCvolts + RLCvolts;
float dragforce = MLCvolts;
if ((lastLog + LOG_RATE) <= millis())
{ // If it's been LOG_RATE milliseconds since the last log:
if (tinyGPS.location.isUpdated())
if (logGPSData())
SerialMonitor.println("GPS logged.");
lastLog = millis(); // Update the lastLog variable
SerialMonitor.println("Failed to log new GPS data.");
else // If GPS data isn't valid
// Print a debug message. Maybe we don't have enough satellites yet.
SerialMonitor.print("No GPS data. Sats: ");
SerialMonitor.println(tinyGPS.satellites.value());
while (gpsPort.available())
tinyGPS.encode(gpsPort.read());
byte logGPSData()
File logFile = SD.open(logFileName, FILE_WRITE); // Open the log file
if (logFile)
{ // Print longitude, latitude, altitude (in feet), speed (in kmph), course
// in (degrees), date, time, and number of satellites.
logFile.print(downforce);
logFile.print(',');
logFile.print(dragforce);
logFile.print(',');
logFile.print(tinyGPS.speed.kmph(), 1);
logFile.print(',');
logFile.print(tinyGPS.date.value());
logFile.print(',');
logFile.print(tinyGPS.time.value());
logFile.println();
logFile.close();
return 1;
return 0;
void printHeader()
if (logFile)
int i = 0;
for (; i < LOG_COLUMN_COUNT; i++)
logFile.print(log_col_names[i]);
if (i < LOG_COLUMN_COUNT - 1)
logFile.print(',');
logFile.println(); // print a new line
logFile.close(); // close the file
void updateFileName()
int i = 0;
for (; i < MAX_LOG_FILES; i++)
memset(logFileName, 0, strlen(logFileName));
sprintf(logFileName, "%s%d.%s", LOG_FILE_PREFIX, i, LOG_FILE_SUFFIX);
if (!SD.exists(logFileName))
+ SerialMonitor.print(logFileName);
SerialMonitor.println(" exists");
SerialMonitor.print("File name: ");
SerialMonitor.println(logFileName);
