reading logarithmic values on linear potentiometer
Hey!
I'm trying to read my new slide potentiometer
data sheet: http://files.voelkner.de/675000-699999/675480-da-01-en-60MM_DUAL_SCHIEBEPOTI_PS60M_10K_20_.pdf
(without LED)
but unfortunately I'm getting logarithmic values. I checked with the multimeter and it gives me 5k at center position as it should, but on the seriell monitor I get 16 at the same position where it should be around 500-512, shouldn't it? :o
thanks in advance for your help!
If you're getting 5k resistance at middle it's not a log pot; I suspect it's wired wrong.
I'm sure all could be explained knowing your pot's part#, how its connected and your code.
The data sheet you referenced tells you there are three different resistance tapers available and they are A, B, and C. Only B is linear taper. What model number do you have?
Paul
SymonCarpenter: I checked with the multimeter and it gives me 5k at center position as it should, but on the seriell monitor I get 16 at the same position where it should be around 500-512, shouldn't it? :o
Did you connect all three pins. +5volt, ground, and taper.
You could get low values if the 5volt connection is missing. Leo..
thank you very much for your help!
Turns out I confused the taper and the ground pin.
feeling a little bit stupid now
Don't feel stupid, we all make mistakes, and have to learn by them. I'm glad you have got it sorted out.
