Reading Micronet nmea signal
Ciao a tutti. I'm looking for sniffing signal from my raymarine wind station t101.
I understood that probably the signal is a Micronet RT signal, but I don't know how can I read the Nmea flow inside.
My scope is sniffing/reading the signal and display the value.
Have you any suggestion for me? do you know similar project?
Tks ciao Fabio
This may be similar to how you decode wireless weather station data but this depends on how the equipment works. If it needs pairing or the device only sends data when requested then it may be more difficult.
I would try to use a logic analyser to capture the data so you can record the stream and decode it with known sent values or you could try searching for other who have trodden this path before you.
