Reading Modbus 32 bit holding Registers
Hi All,
I am looking to create some code to periodically log Temperature, Humidity, Barometric Pressure and Light Intensity from a SenseCAP ORCH S4 Version V1.1 to an SD card using an Arduino UNO or NANO, an RS485 to TTL converter and a real time clock.
The Arduino with the SD card and the RTC, a battery and a solar panel will be mounted in an IP66 rated enclosure on a pole with the ORCH S4. The logging interval is 6 minutes (10 per hour).
The User manual can be obtained from the following if required: [https://files.seeedstudio.com/products/101990661/doc/SenseCAP%20ORCH%20S4%20-%20User%20Guide%20v1.1.pdf]
I am very thankful to this Forum for providing the code to extract the data from the unit.
I have modified it code to my requirements and have successfully read the data from the 16 bit Holding Registers 0x0000(Temperature) and 0x0001(Humidity). I am having difficulty reading the 32 bit registers for Air Pressure 0x0002 & 0x0003 and Light intensity 0x0004 & 0x0005
The default address of my unit is 14
I can code all of the maths to to convert the raw data to decimal numbers and incorporate the RTC and SD card code, but I cant get the raw data from the 32 bit registers.
Code as follows:
// Code taken from following Forum
// https://forum.arduino.cc/t/error-in-communication-modbus-rtu-and-arduino/584876
#include <ModbusMaster.h>
`Use code tags to format code for the forum`/*!
  We're using a MAX485-compatible RS485 Transceiver.
  Rx/Tx is hooked up to the hardware serial port at 'Serial'.
  The Data Enable and Receiver Enable pins are hooked up as follows:
int MAX485_RE_NEG = 3;
int MAX485_DE = 2;
// #define MAX485_RE_NEG  3
// #define MAX485_DE      2
// instantiate ModbusMaster object
ModbusMaster node; // ModbusMaster called as node
void preTransmission()
  digitalWrite(MAX485_RE_NEG, 1); // Set to Transmission Mode
  digitalWrite(MAX485_DE, 1);
void postTransmission()
  digitalWrite(MAX485_RE_NEG, 0); // Set to Receive Mode
  digitalWrite(MAX485_DE, 0);
  pinMode(MAX485_RE_NEG, OUTPUT);
  pinMode(MAX485_DE, OUTPUT);
  // Init in receive mode
  // Modbus slave ID 14
  node.begin(14, Serial);
  // Callbacks allow us to configure the RS485 transceiver correctly
  node.preTransmission(preTransmission);
  node.postTransmission(postTransmission);
  uint8_t ReadResult;
  ReadResult = node.readHoldingRegisters(0x0000,3);
  if (ReadResult == node.ku8MBSuccess)
    Serial.print("\nTemperature: ");
    Serial.println(node.getResponseBuffer(0x00) / 100.0f);
    Serial.print("\nHumidity: ");
    Serial.println(node.getResponseBuffer(0x01) / 100.0f);
    Serial.println(node.getResponseBuffer(0x03) / 100.0f);
    Serial.println(node.getResponseBuffer(0x04) / 100.0f);
  delay(5000);
I would greatly appreciate any assistance offered.
Many thanks
Stuart
It shows you how to do this in the manual you linked to, page 8.
When you read a register, you are reading a 16 bit quantity. Temperature is a 16 bit value, humidty is a 16 bit value, but barometric pressure is a 32 bit value so you are reading 4 16-bit registers, not 3.
ReadResult = node.readHoldingRegisters(0x0000,4);
The manual shows you that you combine register 2 and register 3:
Value=(uint32)(Register 0x0002 << 16 + Register 0x0003)
so that would be
uint32_t pressure = (uint32_t)node.getResponseBuffer(2) << 16 + node.getResponseBuffer(3);
Serial.println(pressure);
The same can be done for light intensity (reading 2 more registers, combining them like above)
