Reading multiple button states using one pin and digital pins to supply power
Hi all.
I am trying to read the values of button presses using just one digital input pin. My approach is to power the buttons using digital pins as output and only turn on one output pin at a time, cutting the power to the button so as to not read from it when its off. This works well when I press one button at a time and I receive the expected output. However, when I hold down both buttons what I'm expecting to read is:
Slot: 0
start buttonState: 1
Power Pin 2 forward is high
End buttonState: 0
Slot: 1
Power Pin 13 forward is high
End buttonState: 0
but instead what I receive is:
Slot: 0
start buttonState: 0
End buttonState: 0
Slot: 1
End buttonState: 0
Also, this is not always consistent. Sometimes while holding both one will still read as high but not both. I understand I'm using an unorthodox method so I suspect they may be what is causing problems for me. I have seen other methods of using just one pin for multiple buttons so I am aware I have other options, I'm just curious if this method is even feasible. I've provided a circuit diagram (I'm using 10k resistors for pull-down) and my code below. Any help is very appreciated!
const int powerPins[2] = { 2, 13 };
int buttonPin = 4;
  pinMode(buttonPin, INPUT);
  for (int i = 0; i < 2; i++) {
    pinMode(powerPins[i], OUTPUT);
  digitalWrite(powerPins[0], HIGH); //turn first slot on
  digitalWrite(powerPins[1], LOW); //turn others off
    Serial.println("Slot: " + String(i));
    Serial.println("start buttonState: " + String(digitalRead(buttonPin))); //for troubleshooting
    if (digitalRead(buttonPin) == HIGH ) {
      Serial.print("Power Pin ");
      Serial.print(powerPins[i]);
      Serial.println(" forward is high");
    digitalWrite(powerPins[(i + 1) % 2], HIGH); // turn the neighbouring pin on
    digitalWrite(powerPins[i], LOW); //turn off current power pin so we dont read this button
    Serial.println("End buttonState: " + String(digitalRead(buttonPin)));
This is just a simplified scenario. Its for a school project and i need more than the alloted pins so im trying to save on using pins. As for frying the arduino I have tried and ran this program and the arduino seems to be working fine.
So, if you need many switches, maybe a key matrix would be a good solution ?
Or, use an analog input with an R2R ladder arrangement !
Because i have other hardware connected to the arduino using pins that is not shown in this scenario I also need 12 buttons total .
Im not sure if im misunderstanding you? I have other hardware taking up pins so i only have four pins to work with and i have 12 buttons
I understand now, sorry for the miscommunication on my part. I have a different setup for my project which is 4 slots with 3 strips of copper tape laid on one side and 1 strip of copper tape on the other side. The three strips are my inputs(3x4=12) and the one strip on the other side is the power pin so i only need 4 power pins. I then have blocks with copper tape on the bottom so when i place it into a slot depending on the block it turns a pin high. It works for the most part expect when i put in two blocks that are the same. I just used this scenario as an example to simplify it
like this?
const int powerPins[2] = { 3, 5 };
int buttonPin = 2;
int buttonState = 0;
  pinMode(powerPins[0], OUTPUT);
  pinMode(powerPins[1], INPUT);
    pinMode(powerPins[(i + 1) % 2], OUTPUT);
    pinMode(powerPins[i], INPUT);
Edit* : I just tried this and it works. I am so thankful this was bugging me for 3 days!!!! thank you for replying so promptly i am so happy!
Will do! Thank you again so much, I am so relieved.
