reading multiple photosensors separately so relais don't jitter
Hey guys and girls,
i'm stuck with my code, seems simple; 6 photosensors that look for a bright light en if the light is present a relais switch will turn ON. i got this far but when 2 sensors (or more) get light input at the same time it jitters because of the delay i inserted. even without the delay it jumps between the channels that got input.
i can't find out how to code it so multiple switches stay ON at the same time.
also: i can't find a trick so that i have 8 analog inputs on my Arduino UNO. tips anyone?
thanx in advance
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);  // relais
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(7,OUTPUT);
void loop(){
digitalWrite(2, HIGH);
digitalWrite(3, HIGH);
digitalWrite(4, HIGH);
digitalWrite(5, HIGH);
digitalWrite(6, HIGH);
digitalWrite(7, HIGH);
Serial.println(analogRead(A0));
if (analogRead(A0) > 950){
  LampEen();
//Serial.println(analogRead(A0));
if (analogRead(A1) > 950){
  LampTwee();
if (analogRead(A2) > 950){
  LampDrie();
void LampEen(){
  digitalWrite(2,LOW);
  delay(100);
 // digitalWrite(2,HIGH);
void LampTwee(){
  digitalWrite(3,LOW);
  delay(100);
 // digitalWrite(3,HIGH);
void LampDrie(){
  digitalWrite(4,LOW);
   delay(100);
  // digitalWrite(4,HIGH);
void LampVier(){
  digitalWrite(5,LOW);
 // delay(100);
 // digitalWrite(5,HIGH);
void LampVijf(){
  digitalWrite(6,LOW);
 // delay(100);
  //digitalWrite(6,HIGH);
void LampZes(){
  digitalWrite(7,LOW);
 // delay(100);
 // digitalWrite(7,HIGH);
By the way, i think it is because of the -IF- statements but can't find out what the proper way to do is.
pardon my english, i'm dutch and learning... code i mean. my english is just not that good.
Made a slight change.
with a WHILE statement it does is more like i want to but still not the optimal. when i shine a bright light over the first sensor and then second, third and so on it keeps all the relais in HIGH but when i do it in the opposite direction it doesn't (off course because the code goes from top to bottom)
how to fix this issue??
hope someone is willing to help me out!
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(7,OUTPUT);
void loop(){
while (analogRead(A0) > 950){
  LampEen();
while (analogRead(A1) > 950){
  LampTwee();
while (analogRead(A2) > 950){
  LampDrie();
void LampEen(){
  delay(300);
void LampTwee(){
  delay(300);
void LampDrie(){
   delay(300);
void LampVier(){
 // delay(100);
void LampVijf(){
 // delay(100);
void LampZes(){
 // delay(100);
