Reading multiple sensors
Hi everybody.I’m new to Arduino.In my project i have to read multipe sensor values and send them to serial port.I had no problem when i use the codes seperate. But i need all of values at the same time.i cant read light sensor values. searched on forums but didnt work for me.Im using light sensor, tilt sensor and LM35.I need your help.
Here is my code:
int TempPin = 0;
int TempVal;
float Sicaklik;
int inPin = 7;
int value = 0;
int led = 13;
const int sensorPin = A1;
int sensorValue = 0;
int sensorMin = 1023;
int sensorMax = 0;
  analogReference(INTERNAL);
  pinMode(led, OUTPUT);
  pinMode(inPin, INPUT);
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);
  while (millis() < 5000) {
     sensorValue = analogRead(sensorPin);
     if (sensorValue > sensorMax) {
       sensorMax = sensorValue;
     if (sensorValue < sensorMin) {
       sensorMin = sensorValue;
   digitalWrite(13, LOW);
  value = digitalRead(inPin);
  TempRead = analogRead(TempPin);
  sensorValue = map(sensorValue, sensorMin, sensorMax, 0, 255);
  sensorValue = constrain(sensorValue, 0, 255);
  Temp = TempRead/9.31;
  Serial.println(Temp);
  if ( value == 1 )
    digitalWrite(led, value);
    Serial.println("shaked");
    delay(1500);
  if ( sensorValue > 200 )
    Serial.println("darkside");
thanks in advance.
You are calibrating the MAX and MIN of your light sensor in the first five seconds after power-up. Are you sure you are rotating the device so it can get valid MAX and MIN values? Could your LDR have gotten disconnected?
johnwasser:
LDR is okay.
Ldr works great with this code and can send values to serial port and i can read values. But With the previous codes I cant read values of it.
const int sensorPin = A1;    // pin that the sensor is attached to
const int ledPin = 9;        // pin that the LED is attached to
// variables:
int sensorValue = 0;         // the sensor value
int sensorMin = 1023;        // minimum sensor value
int sensorMax = 0;           // maximum sensor value
   // turn on LED to signal the start of the calibration period:
   // calibrate during the first five seconds
     // record the maximum sensor value
     // record the minimum sensor value
   // signal the end of the calibration period
   // read the sensor:
   // apply the calibration to the sensor reading
   // in case the sensor value is outside the range seen during calibration
   // fade the LED using the calibrated value:
   analogWrite(ledPin, sensorValue);
   Serial.println(sensorValue);
The only different part of the code is here:
Maybe your threshold is set too high? Have you tried displaying the value to see if you reach 200?
I would try something other than arbitrary delays to keep the output rate down. Perhaps only display output when something changes.
johnwasser: The only different part of the code is here:
Yes i did. I can see the values. But when i use all of the sensors at the same time in codes. I cant see temperature .
Hi folks. I still work on this problem but i cant read values.Please help.
In your first message you say: ".i cant read light sensor values. “. In a recent reply you say " I cant see temperature .”
Run your program and cut and paste the output you see in the Serial Monitor window. Then show your current sketch if it has changed any. Point out the places in your output where you expected to see something and don’t see it.
johnwasser:
It is my mistake. I said i can send light sensor values to serial port and can read them with serial monitor(only with this code)
// variables:
   // read the sensor:
. But i cant read only light sensor values with the codes in my first post. I cant solve that problem.
I say again:
Run your program and cut and paste the output you see in the Serial Monitor window. Then show your current sketch if it has changed any. Point out the places in your output where you expected to see something and don't see it.
