can you tell me how I can read simultaneously from multiple sensors SRF04?
I implement the project quadrotor, where I have 4 ultrasounds at 90 degrees. They measure the distance to obstacles. I need to know every 50ms distance to obstacles in each direction (ie from all four sensors). Can someone write at least pseudocode ?
Thanks
If your "object" is moving forward only the front sensors will close up to an obstacle and create an alarm, just reverse, if a rear sensors sees trouble then go forward.
The same thing will apply to side sensors.
When you apply the "reverse movement" put a shift of direction into the motor code, this will get it out of a "boxed in " situation.
