I have (hopefully) just one more problem: I generate a pwm that goes into a resistor circuit; the resistance of the circuit could change and I need to detect that. I thought of using an interrupt to test the value of the pwm I send out, but I'm not sure that works.
int pwmpin = 11; // inject pwm here
int testpin = 9; // check pwm voltage here
volatile int state = LOW, testvalue;
TCCR2B = (TCCR2B & 0xF8) | 3; // ~1khz pwm
pinMode(testpin, INPUT);
attachInterrupt(0, test, CHANGE);
analogWrite(pwmpin, 64); // ~25% duty cycle
Serial.println(testvalue);
void test()
testvalue = analogRead(testpin);
Hi Anachrocomputer - thanks for the reply, but I need the actual value of the pwm after it hits the resistive circuit - if somebody changes the resistance that will change the pwm voltage and I have to know by how much. In fact I need both the high and low voltage parts because that tells me there is a diode in the circuit and the change in resistance is warranted.
I thought the interrupt service routine doesn't apply to any particular pin.
I thought interrupts could only be triggered from digital pins? Maybe you'll need to trigger the interrupt with a digital pin, then read the analog voltage with an analog pin?
You're right - need either pin 2 or 3 and appropriate interrupt.
Tried that - interrupt service is for pin 2 and in the routine I try to read the analog pin 0. No dice.
I think this is not doable because interrupts are being soaked up by the pwm generator.
