Reading open collector output (UVTRON driver board)
Hello, how might I read the output from this driver board? Im using a esp8266.
Thank you !
Connect the module output pin to any pin (can use for input) of ESP8266 as it is, and set pinMode to INPUT_PULLUP.
That's all.
Don't forget to connect the module GND to the ESP8266 GND.
It seems that the timing is the same output 1 and 2 except that the logic is inverted.
arduino
Could you see my attached picture to see if I understand this correctly? thanks for the help.
Good. :+1:
Have fun. :grinning:
