Hmm I tried it and it just went crazy! Maybe if I put the whole sketch here it might help.
#include <Wire.h> // Comes with Arduino IDE
const long seconds_start_delay = 5; // Pause during startup to let PIRs settle down
#define STATE_SHORT 0
#define STATE_NORMAL 1
#define STATE_TAMPER 2
#define STATE_ALARM 3
#define STATE_ALARM_TAMPER 4
#define STATE_CUT 5
#define STATE_UNKNOWN 6
int led = 13;
/* Display config */
#define ENABLE_LCD true // true/false. Enable if you have a Freetronics OLED128 connected
//const long oled_timeout = 20; // Seconds before screen blanks after last activity
/* Analog readings corresponding to different sensor states */
struct input_ranges {
int sensor_state;
const String label;
int range_bottom;
int range_optimum;
int range_top;
const input_ranges ranges[] {
{ STATE_SHORT, "Shorted", 0, 0, 162 }, // 0
{ STATE_NORMAL, "Normal", 163, 326, 409 }, // 1
{ STATE_TAMPER, "Tamper", 410, 495, 551 }, // 2
{ STATE_ALARM, "Alarm", 552, 609, 641 }, // 3
{ STATE_ALARM_TAMPER, "Alarm+Tamper", 642, 675, 848 }, // 4
{ STATE_CUT, "Cut", 849, 1023, 1023 }, // 5
{ STATE_UNKNOWN, "Unknown", 1024, 1024, 1024 }, // 6. Range beyond analog in because this is never read
/* Connected sensors */
struct sensor {
const String label;
byte analog_input;
byte status_output;
byte last_state;
sensor sensors[] {
{ "A", 0, 4, STATE_UNKNOWN },
{ "B", 1, 5, STATE_UNKNOWN },
{ "C", 2, 6, STATE_UNKNOWN },
{ "D", 3, 7, STATE_UNKNOWN },
long lastActivityTime = 0;
char messageBuffer[100];
char topicBuffer[100];
char clientBuffer[20];
/*-----( Declare Constants )-----*/
/*-----( Declare objects )-----*/
// set the LCD address to 0x27 for a 16 chars 2 line display
// A FEW use address 0x3F
// Set the pins on the I2C chip used for LCD connections:
// addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
//if (seconds_start_delay > 0)
if ( ENABLE_LCD == true )
lcd.begin(16,2); // initialize the lcd for 16 chars 2 lines, turn on backlight
// ------- Quick 3 blinks of backlight -------------
for(int i = 0; i< 3; i++)
lcd.backlight();
delay(250);
lcd.noBacklight();
delay(250);
lcd.backlight(); // finish with backlight on
//-------- Write characters on the display ------------------
// NOTE: Cursor Position: (CHAR, LINE) start at 0
lcd.setCursor(0,0); //Start at character 4 on line 0
lcd.print("Alarm System");
lcd.setCursor(0,1);
lcd.print("C Brennan V1.0");
delay(8000);
lcd.clear();
Serial.print("Pausing ");
Serial.print( seconds_start_delay );
Serial.println(" seconds to let sensors settle");
lcd.setCursor(0,0);
lcd.print(F("Pausing "));
lcd.setCursor(0,1);
lcd.print(seconds_start_delay, DEC);
lcd.print(" Secs to settle");
delay(seconds_start_delay * 1000);
lcd.clear();
const byte sensorPins[] = {A0, A1, A2, A3};
for (int pinIndex = 0; pinIndex < 3; pinIndex++) {
processSensor(sensorPins[pinIndex]);
void processSensor( byte sensorId )
int sensorReading = analogRead( sensors[sensorId].analog_input );
//Serial.print(sensorId, DEC);
//Serial.print(": ");
//Serial.println(sensorReading, DEC);
byte sensorState = STATE_UNKNOWN;
// This should check all entries in the states struct:
if ( (sensorReading >= ranges[STATE_SHORT].range_bottom) && (sensorReading <= ranges[STATE_SHORT].range_top) ) {
sensorState = STATE_SHORT;
digitalWrite (led, HIGH);
} else if ( (sensorReading >= ranges[STATE_NORMAL].range_bottom) && (sensorReading <= ranges[STATE_NORMAL].range_top) ) {
sensorState = STATE_NORMAL;
digitalWrite (led, LOW);
} else if ( (sensorReading >= ranges[STATE_TAMPER].range_bottom) && (sensorReading <= ranges[STATE_TAMPER].range_top) ) {
sensorState = STATE_TAMPER;
} else if ( (sensorReading >= ranges[STATE_ALARM].range_bottom) && (sensorReading <= ranges[STATE_ALARM].range_top) ) {
sensorState = STATE_ALARM ;
} else if ( (sensorReading >= ranges[STATE_ALARM_TAMPER].range_bottom) && (sensorReading <= ranges[STATE_ALARM_TAMPER].range_top) ) {
sensorState = STATE_ALARM_TAMPER;
} else if ( (sensorReading >= ranges[STATE_CUT].range_bottom) && (sensorReading <= ranges[STATE_CUT].range_top) ) {
sensorState = STATE_CUT;
// Compare to previous value
if ( sensorState != sensors[sensorId].last_state )
//lcd.setCursor(0, 1);
// It changed!
byte lastSensorState = sensors[sensorId].last_state;
Serial.print("Sensor ");
Serial.print(sensorId);
Serial.print(" changed from ");
Serial.print(ranges[lastSensorState].label);
Serial.print(" to ");
Serial.println(ranges[sensorState].label);
sensors[sensorId].last_state = sensorState;
String messageString = sensors[sensorId].label + '-' + String(sensorState);
Serial.println(messageString);
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("Event: ");
lcd.setCursor(0,1);
lcd.print(messageString);
delay(5000);
lcd.clear();
lcd.noBacklight();
messageString.toCharArray(messageBuffer, messageString.length() + 1);
String topicString = "sensors";
topicString.toCharArray(topicBuffer, topicString.length() + 1);
