Reading problem after triangle wave input
After hitting triangle wave input with oscilloscope
Use array to average
simply put Is that I want to take the average of the triangle wave
Serial.println(X); The reason for X is that I'm not sure which direction the average value is
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <SPI.h>
#include <Ticker.h>
int val;
byte serialA;
int A=0;
int B=0;
int inputpin0 = A0;
const int n1 = 4;
int data1[n1];           // all array data
int readIndex1 = 0;      // the index1 of the current reading
const int n2 = 256;
int data2[n2];           // all array data
int readIndex2 = 0;      // the index1 of the current reading
    for (int i = 0; i < n1 ;i++) //0~4
    data1[i] = 0;
  for (int i = 0; i < n2 ;i++) //256
    data2[i] = 0;
  pinMode(A0,INPUT);
  delay(10);
  timer1_attachInterrupt(timerIsr);
  timer1_enable(TIM_DIV16, TIM_EDGE, TIM_SINGLE);
  timer1_write(4166.66);
   Serial.println(X);
   delay(50);
void timerIsr()
  data1[readIndex1]= analogRead(inputpin0);
  data2[readIndex2]=(data1[0]+data1[1]+data1[2]+data1[3])/4;
  readIndex2 = readIndex2 + 1;
   if(readIndex2 >= n2 )
    readIndex2 = 0;
   byte Data[2];
    B=B+1;
    Data[0]=data2[readIndex2]/256;
    Data[1]=data2[readIndex2]%256;
    if (A==1){
      if (B>=4){
      for(int j=0;j<2;j++)
     Serial.write(Data[j]);
      B=0;
   readIndex1 = readIndex1 + 1;
   if(readIndex1 >= n1 )
    readIndex1 = 0;
An += (Sn - An-1) * K
where An is the current average, Sn the current sample and K, a value < 1 which is the time constant for averaging.
gcjr:
I can understand mathematically
But into code
I may need to take a moment to understand
asas80185:
that would be zero for triangle wave, with range from -V to -V and period T.
Are we right to assume that your triangular wave is always >0 ?
sherzaad:
The values of my triangle wave input >0
asas80185:
assuming it is a symmetric triangular wave then, the average value for the triangle wave is Vp-p/2.
so in code, you could simply continuously capture samples discarding the 'previous' value if the 'new' value is greater.
then as soon as you get a value where 'new' < 'previous' assume that 'previous' was the '+peak' value.
no do the converse to get '-peak'
Then divide '+peak' - '-peak' by 2 to get the 'average'
repeating that you could average a series of '+peak' and '-peak' values to get a more accurate average IMHO.
hope that helps.
