Reading Problem from RC Receiver
Hi Guys,
I have a weird problem. Hope you guys help to solve my problem. Here is the code.
#include <PinChangeInt.h>
// MultiWii SE v2.5 Pins (2-6-4-5)
// MultiWii Crius AIO Pro (A8-A11-A9-A12)
#define ch1 2 //A8 // 2 //Thro - R9D(3)
#define ch2 6 //A11 //6 //Rudd - R9D(4)
#define ch3 4 //A9 //4 //Aile - R9D(1)
#define ch4 5 //A10 //5 //Elev - R9D(2)
#define LiPo 7 //A12 //7 //Aux for Bigger LiPo of Motor
// External Interrupts
// Necessary to Read RC Receiver
volatile int Thro_value = 0; //ch1 - Thro
volatile int Rudd_value = 0; //ch2 - Rudd
volatile int Aile_value = 0; //ch3 - Aile
volatile int Elev_value = 0; //ch4 - Elev
volatile int AUX_value = 0; //LiPo - AUX
volatile int RPM_value = 0; //LiPo - AUX
volatile int Thro_prev_time = 0;
volatile int Rudd_prev_time = 0;
volatile int Aile_prev_time = 0;
volatile int Elev_prev_time = 0;
volatile int AUX_prev_time = 0;
volatile int RPM_prev_time = 0;
uint8_t Thro_pin; // for CRUIS AIO Pro
uint8_t AUX_pin;
uint8_t Rudd_pin;
uint8_t Elev_pin;
uint8_t Aile_pin;
uint8_t RPM_pin;
  Serial.begin(57600); // Pour a bowl of Serial
  // Input Pins
  // when pin D2 goes high, call the rising function
  // Thro pin
  attachInterrupt(0, Thro_rising, RISING); // for MultiWii SE v2.5
  //pinMode(ch1, INPUT); digitalWrite(ch1, HIGH); //Thro // for Crius AIO Pro
  pinMode(ch2, INPUT); digitalWrite(ch2, HIGH); //Rudd
  pinMode(ch3, INPUT); digitalWrite(ch3, HIGH); //Aile
  pinMode(ch4, INPUT); digitalWrite(ch4, HIGH); //Elev
  pinMode(LiPo, INPUT); digitalWrite(LiPo, HIGH); //Aux for LiPo
  //PCintPort::attachInterrupt(ch1, Thro_rising,RISING); // for Crius AIO Pro
  PCintPort::attachInterrupt(LiPo, AUX_rising,RISING);
  PCintPort::attachInterrupt(ch2, Rudd_rising,RISING);
  PCintPort::attachInterrupt(ch3, Aile_rising,RISING);
  PCintPort::attachInterrupt(ch4, Elev_rising,RISING);
  Serial.print(Thro_value); Serial.print(" | ");
  Serial.print(Rudd_value); Serial.print(" | ");
  Serial.print(Elev_value); Serial.print(" | ");
  Serial.print(Aile_value); Serial.print(" | ");
  Serial.print("\n");
void Thro_rising() {
  //Thro_pin=PCintPort::arduinoPin; // for Crius AIO Pro
  //PCintPort::attachInterrupt(Thro_pin, Thro_falling, FALLING);
  attachInterrupt(0, Thro_falling, FALLING); // for MultiWii SE v2.5
  Thro_prev_time = micros();
void Thro_falling() {
  //PCintPort::attachInterrupt(Thro_pin, Thro_rising, RISING);
  Thro_value = micros()-Thro_prev_time;
void AUX_rising() {
  AUX_pin=PCintPort::arduinoPin;
  PCintPort::attachInterrupt(AUX_pin, AUX_falling, FALLING);
  AUX_prev_time = micros();
void AUX_falling() {
  PCintPort::attachInterrupt(AUX_pin, AUX_rising, RISING);
  AUX_value = micros()-AUX_prev_time;
void Rudd_rising() {
  Rudd_pin=PCintPort::arduinoPin;
  PCintPort::attachInterrupt(Rudd_pin, Rudd_falling, FALLING);
  Rudd_prev_time = micros();
void Rudd_falling() {
  PCintPort::attachInterrupt(Rudd_pin, Rudd_rising, RISING);
  Rudd_value = micros()-Rudd_prev_time;
void Aile_rising() {
  Aile_pin=PCintPort::arduinoPin;
  PCintPort::attachInterrupt(Aile_pin, Aile_falling, FALLING);
  Aile_prev_time = micros();
void Aile_falling() {
  PCintPort::attachInterrupt(Aile_pin, Aile_rising, RISING);
  Aile_value = micros()-Aile_prev_time;
void Elev_rising() {
  Elev_pin=PCintPort::arduinoPin;
  PCintPort::attachInterrupt(Elev_pin, Elev_falling, FALLING);
  Elev_prev_time = micros();
void Elev_falling() {
  PCintPort::attachInterrupt(Elev_pin, Elev_rising, RISING);
  Elev_value = micros()-Elev_prev_time;
The code reads both rising and falling edges of 5 channels from RC receiver and it gives the values btw 1000 and 2000 approximately.
However, it gives me annoying number such as 13198. I think it is total period not duty cycle. When I move any stick, the related channel gives the right value but suddenly changes to 13900, 8621, 4568 ridiculously.
Looking forward to your response…
Why do you use PCintPort::attachInterrupt() in setup, and attachInterrupt() when detaching and reattaching the interrupt handlers in the interrupt service routines? They are NOT interchangeable.
You are right. PCintPort::attachInterrupt() makes them to interrupt handlers thanks to <PinChangeInt.h> library.
When I want to read just two of them, it works succesfully but for four of them, it is not.
Please Help!..
Please Help!..
You changed your code.
You didn't post it.
We can't.
It's that simple.
