Reading problems between Arduino and Python
Hello!
As a beginner in using Arduino and Python, I’m trying to make run some examples from the Internet in order to have a greater challenge for the future.
I’m Trying to make run the program from this website : http://www.stealthcopter.com/blog/2010/02/python-interfacing-with-an-arduino/
Actually, I am using these codes:
For my Arduino (Uno):
     int ledPin = 13;  // choose the pin for the LED
    int val = 0;      // variable for reading the pin status
    char msg = ' ';   // variable to hold data from serial
      pinMode(ledPin, OUTPUT);      // declare LED as output
      loop();
      Serial.print("Program Initiated\n");
    void loop(){
            // While data is sent over serial assign it to the msg
        while (Serial.available()>0){
            msg=Serial.read();
       Serial.print("Program really Initiated\n");
      if (msg=='Y') {
        digitalWrite(ledPin, HIGH);  // turn LED ON
        Serial.print("LED Activated\n");
        msg=' ';
      } else if (msg=='N') {
        digitalWrite(ledPin, LOW); // turn LED OFF
        Serial.print("LED Not Activated\n");
      }  else { Serial.print("Cannot read...\n");}
For Python :
import serial
import time
locations = ['COM1', 'COM2','COM3','COM4','COM5','COM6','COM7','COM8','COM9']
for device in locations:
    try:
        print "Trying...",device
        arduino = serial.Serial(device, 9600)
        break
    except:
        print "Failed to connect on",device
try:
    arduino.write('Y')
    time.sleep(1)
    print arduino.readline()
except:
    print "Failed to send!"
My problem is that that the console display the messages, until the condition “if”. The board doesn’t work, it soesn’t display the message in the “if” condition and the led are not blinking for just run. I don’t know what to do… Do you know what is the problem?
Thanks!
      loop();
Why are you calling loop() from setup()?
            msg=Serial.read();
The comment is wrong. What it should say is
// While data is sent over serial, throw away all by the last character, which get stored in msg
You get output from the Python program that you didn't bother to share. You see, or do not see, the LEDs on the Arduino blink. You didn't share that information, either.
I think the exact same code is the subject of this thread Serial communication from Linux to arduino nano ok. mega 2560 not activating. - #8 by Robin2 - Interfacing w/ Software on the Computer - Arduino Forum
It may be worth looking at.
...R
