reading sd file line by line, intersected with "code"
Thanks for the reference to strtok.
I managed to get the following code, but with one last issue, in the void readSD, where i call the function readCode, i need to have to myFile.read converted to a char* i tried several options but couldn't get it to work right.
Also the myFile.read is seen as an int, which should be a string as it contains non-numbers.
I managed to convert it to char, but then ofcourse i get the error cannot convert char to char*
#include <string.h>
#include <SPI.h>
#include <SD.h>
File myFile;
int SSPIN = 4;
int joints = 4;
char delimiters[] = " xH yH zH J ";
int frametime = 0;
  while (!Serial) {
  Serial.print("Initializing SD card...");
  if (!SD.begin(SSPIN)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  //char instring[] = "xH 16.3 yH 5.5 zH 40.5 J 30.3";
void readSD ()
  myFile = SD.open("test.txt");
  if (myFile) {
    Serial.println("test.txt:");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
      readCode(myFile.read());
    // close the file:
    myFile.close();
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
void readCode (char instring[])
  char* valPosition;
  //This initializes strtok with our string to tokenize
  valPosition = strtok(instring, delimiters);
  if(valPosition != NULL){
    for(int i=0; i < joints; i++)
      if(i == 0)
            Serial.println("Move Servo xH to:");
      if(i == 1)
            Serial.println("Move Servo yH to:");
      if(i == 2)
            Serial.println("Move Servo zH to:");
      if(i == 3)
            Serial.println("Frame Delay:");
      Serial.println(valPosition);
      frametime = atof(valPosition);
      //Here we pass in a NULL value, which tells strtok to continue working with the previous string
      valPosition = strtok(NULL, delimiters);
    Serial.println("Delay:");
    Serial.println(frametime);
    delay(frametime);
