In addition I have a level sensor which reads either 1 when it is above water, and 0 when it is below.
I need to be able to give the value of this sensor to a modbus master over rs485.
Cooking Hacks Tutorial
This page has a description of how to use the ModbusMaster485 library, but I can not find any information about the slave library.
Is there anyone who has used these components before, and has an idea of how to get this to work?
I quickly looked at the library and took the example they have for slave and made some modifications that might suit you better for your needs.
Try the following code:
* Program to sense state of level switch and
* make state available to a Modbus master.
#include <RS485.h>
#include <ModbusSlave485.h>
#include <SPI.h>
ModbusSlave485 mbs; // create new mbs instance:
// Slave registers
enum {
MB_0, // register 0:
MB_REGS // leave here for size of array:
const int pin_level_swicth = 2; // pin that level switch is connected to:
int level_switch = 0;
int regs[MB_REGS];
* void setup()
* Initial setup of board:
pinMode(pin_level_switch, INPUT); // set Arduino input pin for level switch as input (default):
Serial.begin(115200); // intiate serial port for comms at 115200:
const unsigned char SLAVE = 1; // modbus slave configuration parameter:
const long BAUD = 9600; // modbus baud configuration parameter:
mbs.configure(SLAVE, BAUD); // instanstiate modbus object:
* void loop()
* Mission Control:
mbs.update(regs, MB_REGS); // pass current register values to mbs:
level_switch = digitalRead(pin_level_switch); // read level switch into variable:
regs[MB_0] = level_switch; // place digital input value into Modbus registers:
delay(20); // short delay, but should use time check method instead:
