Reading Serial Data From Xbee Issues
I'm using the standard software serial example, changed the pins to reflect the ones in use, and set the serial speed to 9600. When the receiver xbee gets data, it prints to the console, but only in weird characters. Am I supposed to do something to get readable data? I get the same results when hooking the xbee up directly to the computer and reading the data from the COM port.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(0, 1); // RX, TX
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("Goodnight moon!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  mySerial.println("Hello, world?");
void loop() // run over and over
  if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available())
    mySerial.write(Serial.read());
The hardware serial port uses pins 0 and 1. It doesn't make sense to put a software serial instance there as well.
Sorry for sounding dumb but I'm still quite new at this :wink:
So if I am able to receive data like this from the xbee, how do I get the arduino to intelligently interpret it?
