reading serial port
I’ve got problems storing the byte read from the serial port. Here is the code:
long interval = 1000;
long previous = 0;
char string[300];
  int j;
  for(j=0; j<300; j++) {string[j] = '\0';}
  unsigned long start = millis();
  byte p;
  char c;
  int i=0,j;
   if (Serial.available()>0) {
     while (Serial.available() >0) {
      c=Serial.read();
      string[i] = c;
      //Serial.print("i: ") ;
      i++;
   if (start-previous > interval) {
     Serial.print("string: ");
     Serial.println(string);
     previous = start;
Using serial monitor I send “123456”, but the I’ve got
string: 6
While un-commenting the line:
I’ve got:
i: i: i: i: i: i: string: 123456
string: 123456
Obviously I’d like to have the “123456” string. Can anyone help me to explain the situation?
Thank you in advance,
Briefly: Serial communications are slow, microcontrollers are fast.
Slowing your sketch down by adding delays (or in your case prints) allows the serial comms to catch up.
Try sending 1234567890 followed by ABCD. Prepare to be disappointed. Prepare to learn the difference between a string and an array of chars to resolve the problem.
This slightly different version will probably do what you want.
loop() is executed very often if you don’t slow it down (by using Serial.print()). If you start your string (by setting i to 0) in every run, you won’t get much string.
long previous = 0;
char string[300];
int i = 0;
  int j;
  byte p;
  char c;
  int j;
      c=Serial.read();
      string[i] = c;
      i++;
     previous = start;
     i=0;
Which, of course, is why you need start and end of packet markers to properly manage serial data. Receiving strings bounded by start and end markers is then trivial:
#define SOP '<'
#define EOP '>'
bool started = false;
bool ended = false;
char inData[80];
byte index;
   Serial.begin(57600);
   // Other stuff...
  // Read all serial data available, as fast as possible
  while(Serial.available() > 0)
    char inChar = Serial.read();
    if(inChar == SOP)
       index = 0;
       inData[index] = '\0';
       started = true;
       ended = false;
    else if(inChar == EOP)
       ended = true;
      if(index < 79)
        inData[index] = inChar;
        index++;
  // We are here either because all pending serial
  // data has been read OR because an end of
  // packet marker arrived. Which is it?
  if(started && ended)
    // The end of packet marker arrived. Process the packet
    // Reset for the next packet
    started = false;
    ended = false;
    index = 0;
Before to try with communication markers, I’ve tryed with this code:
long interval = 3000;
long previous = 0;
char string[300];
int i=0;
  int j;
  byte p;
  char c;
  int j;
      c=Serial.read();
      string[i] = c;
      //Serial.print(c) ;
      delay(10);
      i++;
     previous = start;
     i=0;
That is working very well with short messagges, but when I try with:
#1234567890#0#1234567890#1#1234567890#2#1234567890#3#1234567890#4#1234567890#5#1234567890#6#1234567890#7#1234567890#8#1234567890#9#1234567890#10#1234567890#11#1234567890#12#1234567890#13#1234567890#14#1234567890#15#1234567890#16#1234567890#17#1234567890#123
I obtain:
string: #1234567890#0#1234567890#1#1234567890#2#1234567890#3#1234567890#28
Is there another obvious reason for this behaviour?
A break of 10ms or more in the transmission?
This is depending only on a variable set in the body of the if block (previous). Let's assume you're sending the big string when start - previous is at 998. You get as many characters as the serial interface gets (there's a limit for the buffer, 64 I think). You're not reading for a second but only for 2 ms giving about 23 bytes for the baud rate you chose.
@pylon: I don't think that's the reason - if you look at the "while" loop, you'll see a 10 ms delay in it.
Normally at this rate, that would be enough time to receive 115 characters, so you would expect the receiver to stay locked in the "while" loop, until a break of at least 10 milliseconds.
I've put 10ms delay inside the loop.
This is the complete transmission
string:
string:
string:
Why the string is always the same?
@AWOL: Correct, I looked at the code I posted, there was no delay. My fault, should always look at the newest posted code :-).
Because the data is already in your array - you're resetting the index, but not treating the array like a C string, terminating it each time you read in a new character.
Exactly. See reply #2.
Sorry,
I’ve update the code with your suggestion (if I understand):
long previous = 0;
char string[300];
int i=0;
  int j;
  byte p;
  char c;
  int j;
      c=Serial.read();
      string[i] = c;
      string[i+1] ='\0';
      //Serial.print(c) ;
      delay(10);
      i++;
     previous = start;
     i=0;
I’ve got the following result…
string:
string:
string: #1234567890#0#1234567890#1#1234567890#2#1234567890#3#1234567890#29
Why I didn’t solve the problem?
You're also overflowing your serial buffer. At 115200 baud rate, you're transmission rate is about 11 characters per millisecond. With a 10msec delay, you can potentially receive 11.5*10= 115 characters during your delay. You then grab a single character and delay another 10msec. The serial buffer will quickly overflow if you send a long string of data.
Bottom line is, delay() should never be used to sync up serial communications. As Pauls has already said (but I'll restate more emphatically), the ONLY way to properly and reliably sync up nontrivial serial communications is with start and end of packet markers.
Sorry,
115200 symbols per seconds *0.001 s = 115.2 symbols per milliseconds. Why 11 characters?
115200 Baud = 115200 bits per second = 11520 bytes per second = ~ 11 bytes per ms
Hint: 1 byte has 8 bits plus 1 start bit and 1 stop bit
     previous = start;
     i=0;
Resetting i here is useful, but it does nothing to the data in string. So, next time around, the data is printed again.
Add:
     string[i] = '\0';
after
     i=0;
From wikipedia
It seems that baud rate is bit rate / 10. So:
You should not divide by 10 another time. Bit per second is baud multiply 10.
And I didn't understand the behaviour of arduino
From wikipedia
Baud - Wikipedia
Where on that page did you found the formula baud = bit rate / 10?
The serial interface has only two symbols (0 and 1), so symbols per second is the same as bits per second.
