I have been working with Basic Stamp for many years.
One of my projects uses several Basic Stamp modules that communicate by looking at a looped serial string of 20 bytes. I am using RS232 and serial generated by a BS2 and a Max232. I use 38.4K baud.
For my first Arduino project I would like to look at a serial line that repeatedly sees a 20 byte string of data and be able to identify certain bits to control LEDs or Relays.
I don't have any problem with building the electronics part or making the connections.
I would love to find some sample code that does something similar or uses similar code. I need to assign a serial input pin, load an array and then use some logical function to identify certain bytes and values in the data. Then I need to operate some output registers connected to LEDs and RELAYs.
My prototype system uses the 74HC595 shift register as an output register, but I would be happy to be able to directly operate one of the many IO pins on the Arduino.
I am a quick learner and though I don't have C++ experience, I am quite good a pBasic as used on the Basic Stamp.
I thank anyone in advance if you can point me in the right direction.
BTW -- I have already built a prototype system using the Pro Mini and I am successfully programming and modifying BLINK. So I have at least successfully completed that hurdle.
Greg
