Hi All,
I have an Arduino receiving serial messages form a monitoring system, the Arduino needs to convert these to CAN bus messages for the HMI. The messages take this format: $-0.073,+1.234,0438,00000,5.45,156 there are 4 data fields that I need to extract from the message to convert to CAN bus.
Using the following code I can receive and display the messages via the terminal:
void serialEvent2()
unsigned char inByte;
if (Serial2.available() > 0)
inByte = Serial2.read();
Serial.write(inByte);
if (inByte == '\n')
Serial.println("");
However I cannot separate this into the 4 fields. I have tried reading it into a char array with the following code but it seems to just fill the array with 255.
void serialEvent2()
unsigned char array[40]={'\0'};
if(Serial2.available() > 0)
for (int i=0; i<40; i++)
array[i] = Serial.read();
if (array[i] != '\0')
//Serial.write(array[i]);
Serial.print(array[i]);
Serial.println("");
Can you help me to split this message up?
Many thanks
