Reading Servo Position Through Serial?
Hello I am kinda a noob at programming and electronics so bear with me, why can’t I simply Serial.println(Servo Position); to get the servo position in C? Here is my code and I am trying to get the servo position to output via serial, I don’t want to control the servo through the serial connections which is what Google gave me.
#include <Servo.h>
Servo servo1;
int pos = 0;
  servo1.attach(9);
  for(pos = 0; pos < 180; pos += 1)
    servo1.write(pos);
    delay(15);
  for(pos = 180; pos>=1; pos-=1)
    servo1.write(pos);
    delay(15);
  Serial.println(pos);
why can't I simply Serial.println(Servo Position); to get the servo position in C?
You could, if you had a variable called "Servo Position".
The code you posted does something. What does it do?
PaulS:
Well it doesn't print to the serial terminal thats for sure, the code controls a servo by moving it between position 180 and 1 with a for loop to my understanding. I was using Serial.println(Servo Position); as an example, if you look at the code I called out to pos and variable pos exist but I am getting nothing via the terminal.
Without a servo actually attached, I get 0 in the Serial Monitor about every 6 seconds. Try your code without a servo attached. Do you get 0 every 6.4 seconds?
How about you just move your serial write statements to where the servos are actually being commanded to move?
#include <Servo.h>
Servo servo1;
int pos = 0;
  servo1.attach(9);
    servo1.write(pos);
    delay(15);
    servo1.write(pos);
    delay(15);
