Reading SF9DOF IMU Output using Multiple Serial Input & SoftwareSerial Issue ...
Using a SF Razor 9DOF IMU connected to TX/RX I successfully, and simply, output YAW (in degrees) to the Serial window using the following code:-
  Serial.begin(57600);
  if(Serial.available()) {
    Serial.write(Serial.read());
...the output is set to 57600 Baud & the output shows YAW=40.10 (for example) which is derived from the SF9DOF_AHRS Output code:-
/* This file is part of the Razor AHRS Firmware */
// Output angles: yaw, pitch, roll
void output_angles()
  if (output_format == OUTPUT__FORMAT_BINARY)
    float ypr[3];
    ypr[0] = TO_DEG(yaw);
    ypr[1] = TO_DEG(pitch);
    ypr[2] = TO_DEG(roll);
    Serial.write((byte*) ypr, 12);  // No new-line
  else if (output_format == OUTPUT__FORMAT_TEXT)
    Serial.print("YAW=");
    Serial.print(TO_DEG(yaw)); Serial.print(",");
  //  Serial.print(TO_DEG(pitch)); Serial.print(",");
  //  Serial.print(TO_DEG(roll));
When I move the TX/RX to pin 10 & 11 respectively and adapt the code to read from Pin 10 I get sporadic ASCII outputs, here's my code:-
// include the SoftwareSerial library so you can use its functions:
#include <SoftwareSerial.h>
#define rxPin 10
#define txPin 11
// set up a new serial port
SoftwareSerial mySerial =  SoftwareSerial(rxPin, txPin);
void setup()  {
  // define pin modes for tx, rx:
  pinMode(rxPin, INPUT);
  pinMode(txPin, OUTPUT);
  // set the data rate for the SoftwareSerial port
  mySerial.begin(57600);
  // while (!Serial);
  if (mySerial.available()){
  Serial.write(mySerial.read());
Should be easy, shouldn't it...?
Any advice gratefully received.
Myles
try pins 2/3.
Dont know which timer is involved, but may be a factor in this problem.
