Reading sketch inside arduino
Hi.... i got an arduino... i want to read the code inside it...there is any method to read the sketch or the source code inside the arduino ??....Thnks
no
Unless there is code protection enabled, you can read the binary data off the chip into a hex file. That hex file you could then disassemble into assembly language. That's the closes you can come. You would then have to read and understand the assembler - not easy to do.
avrdude can read the data off the chip. Quite how you'd then disassemble it I can't say.
Yes, you can recover the compiled binary code.
There is no source code in the processor.
