Reading SPEED/EngineRPM from CAN-BUS-Shield
Hey,
after testing the OBD-II UART Adapter from Freematics with no results, i tried the CAN-Bus Shield by Sparkfun. I've written the code using the knowdegle i got from the example codes.
Somehow the serial monitor always prints 0 rpm while having 1000rpm showing on the tachometer of my 2008 Nissan Qashqai.
Here's the code:
#include <Canbus.h>
#include <defaults.h>
#include <global.h>
#include <mcp2515.h>
#include <mcp2515_defs.h>
#include <Wire.h>
int kmh;
int hkmh;
int zkmh;
int ekmh;
int rpm;
int trpm;
int hrpm;
int zrpm;
int erpm;
char buffer[512];
  if(Canbus.init(CANSPEED_500))  {
    Serial.println("CAN-Bus-Verbindung erfolgreich");
  else {
    Serial.println("CAN-Bus-Verbindung fehlgeschlagen");
  Serial.println("Verbindung zu 7-Seg-Anzeige");
    Wire.begin();
  Wire.setClock(100000);
  Serial.println("Setup abgeschlossen");
  Serial.println("Updating");
    Wire.beginTransmission(0x71);
  Wire.write(0x76);
  Wire.endTransmission();
  /*Canbus.ecu_req(VEHICLE_SPEED,buffer);
  kmh = atoi(buffer);
  hkmh = kmh/100;
  zkmh = (kmh - hkmh*100)/10;
  ekmh = (kmh -(hkmh*100) - (zkmh*10));     */
Canbus.ecu_req(ENGINE_RPM, buffer)
Serial.println(buffer);
/*rpm = atoi(buffer);
trpm = rpm/1000;
hrpm = (rpm - (trpm*1000))/100;
zrpm = (rpm - (trpm*1000)-(hrpm*100))/10;
erpm = (rpm - (trpm*1000)-(hrpm*100)-(zrpm*10));*/
The calculation stuff is for splitting the value into single numbers to print them on a 7-segment-display. I've excluded them because i tried to print the value in the serial monitor.
I'd love to see some friendly advices,
Sebastian Huber.
