reading strings into char arrays from serial monitor, and comparing them.
Hey so I'm working on some code for a bluetooth firework launcher. I have been having issues with reading strings into char arrays of the serial monitor and then using the "strcmp" function to compare the the received data to the firing commands. There are a few issues with it, one being it not reading the entire string from the serial monitor , just what seems like the first letter of the data from a bit of testing. Also You can only send it one command once, then it will no longer work. Last thing is that it fires all three MOSFETSs when you send it anything, unless you have it set to do strcmp(str1, str2) == 0; then it doesn't do anything at all. Here is the code:
//Bluetooth firework launcher code
char inSerial[15];
const long  heatTime = 5000;
const byte MOSFET_1 = 5;
const byte MOSFET_2 = 4;
const byte MOSFET_3 = 3;
const byte rx = 0;
unsigned long currentTime;
long waitTime1;
long waitTime2;
long waitTime3;
  pinMode(rx, INPUT);
  pinMode(MOSFET_1, OUTPUT);
  pinMode(MOSFET_2, OUTPUT);
  pinMode(MOSFET_3, OUTPUT);
  allPinsLow();
  currentTime = millis();
  int i = 0;
  if (Serial.available() > 0) {
    while (!Serial.available()) {
      inSerial[i] = Serial.read();
      i++;
    inSerial[i] = '\0';
    CoilCheck(inSerial);
    i = 0;
  //Heats the coils for 5 seconds
  while (waitTime3 > currentTime) {
    //turns on mosfet 3
    digitalWrite(MOSFET_3, HIGH);
  while (waitTime2 > currentTime) {
    //tunrs on mosfet 2
    digitalWrite(MOSFET_2, HIGH);
  while (waitTime1 > currentTime) {
    //turns on mosfet 1
    digitalWrite(MOSFET_1, HIGH);
  //shuts off the mosfets, pretty messy but it works.
  if (waitTime1 == currentTime) {
    //shuts off mosfet 1
    digitalWrite(MOSFET_1, LOW);
    Serial.println("Heated 1");
  if (waitTime2 == currentTime) {
    //shuts off mosfet 2
    digitalWrite(MOSFET_2, LOW);
    Serial.println("Heated 2");
  if (waitTime3 == currentTime) {
    //shuts off mosfet 3
    Serial.println("Heated 3");
// writes all pins low
void allPinsLow() {
  digitalWrite(MOSFET_3, LOW);
void CoilCheck(char inStr[]) {    //compares recived data to firing commands
  //fires 1
  if (strcmp(inStr, "fire1") == 0) {
    waitTime1 = currentTime + heatTime;
    Serial.println("Firing 1");
    for (int m = 0; m < sizeof(inStr); m++) {
      Serial.println("Here");
      inStr[m] = 0;
  //fires 2
  if (strcmp(inStr, "fire2") == 0) {
    waitTime2 = currentTime + heatTime;
    Serial.println("Firing 2");
      inStr[m] = 0;
  //fires 3
  if (strcmp(inStr, "fire3") == 0) {
    waitTime3 = currentTime + heatTime;
    Serial.println("Firing 3");
      inStr[m] = 0;
Thanks in advance!
These should be unsigned long:
long waitTime1;
long waitTime2;
long waitTime3;
The problem here is that you check to see if there is serial data available, then have a loop that only executes if serial data is NOT available:
      i++;
    inSerial[i] = '\0';
    i = 0;
Also, you do not need to set i = 0 since it will be set to 0 every time loop() function executes.
