Reading strings, program works once, then fails, not sure why
I found an old example code on this forum to learn from, it is supposed to read the string from the serial monitor input until it hits a "X". e.g type "testX" into serial monitor.
It then prints the string it received (test), and then it prints the first 3 charchters of the string (tes).
It works fine the first time, but the second time i try it prints out the string, but then it only prints out the first charchter of the string.
The string is reset in the code, so i'm not sure why it doesn't work.
Serial monitor output from inputting "testX" twice:
serial delimit test 1.0
test
First three characters are: tes
test
t
this is the code:
//zoomkat 3-5-12 simple delimited 'X' string
//from serial port input (via serial monitor)
//and print result out serial port
String String1;
  Serial.println("serial delimit test 1.0"); // so I can keep track of what is loaded
  //expect a string like 123467890X
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == 'X') {
      //do stuff
      Serial.println(String1); //prints captured string to serial port out
      String1 = String1.substring(0, 3); //get the first three characters
      Serial.print("First three characters are: ");
      String1=""; //clears variable for new input
    else {
      String1 += c; //makes the string readString
note - the string was originally called "readString", but i changed it to "String1" because "readString" came up orange in the code and i thought that was the problem. Even when the string is called readString the same problem occurs.
Set the Line ending in the Serial monitor to "No Line Ending" and try again
aha!! that explains why the "t" was printed on the next line too! Thanks!!
