reading the 8 bits (separate) in a byte
Hello,
For controlling 8 outputs I'm using a 74HC595 shift register.
To control the 8 outputs separately I use bitmath:
x |= (1 << n); // forces nth bit of x to be 1. all other bits left alone.
and
x &= ~(1 << n); // forces nth bit of x to be 0. all other bits left alone.
So now I can control the 8 outputs with this code.
But how can I check the state of the outputs when I have the 8 bits (1 Byte) together?
For example:
The shift register has output 1 and 8 ON, and the rest OFF:
0b10000001
How can I check what state output 1 is in my program?
Thanks in advance,
Atmoz
if ( Value & (1 << n) )
  // bit n is set
I personally prefer a "longer" version...
if ( (Value & (1 << n)) == (1 << n) )
Thanks for your fast reply Coding Badly!!
In the meanwhile I found this at another site:
int GetBits3(byte b, int offset, int count)
return (b >> offset) & ((1 << count) - 1);
Works also great :slight_smile:
With kind regards,
Atmoz
You could use the Arduino bitRead function:
if( bitRead(x, 0) )
Serial.print(“the rightmost bit is set”)
if( bitRead(x, 7) )
Serial.print(“the leftmost bit is set”)
See: http://arduino.cc/en/Reference/BitRead
Hmzz, then I get
error: 'bitRead' was not declared in this scope
I think I've to declare something.
I check this tomorrow... (here in the Netherlands it's bedtime) goodnight :wink:
Thanks for all the (fast) help!!
Greetz,
Atmoz
I think it's what version of the Arduino IDE you are using. Bit commands were added around version ?
Lefty
Lefty
0010 Alpha...
I think I should download Arduino 0017 ;D
Is it downwards compatible with the version I have?
With kind regards,
Atmoz
[edit]
No, it's not compatible :-/
I get this error:
C:\Users\Gebruiker\Downloads\arduino-0017\arduino-0017\hardware\cores\arduino/wiring.h:125: error: expected ',' or '...' before numeric constant
In function 'void sendByteOut(int)':
Bad error line: -12
