try this:
float battery_voltage = 3.01; // use voltmeter
analogReadResolution(10);
analogReference(AR_INTERNAL1V0); //AR_DEFAULT: the default analog reference of 3.3V //
AR_INTERNAL1V0: a built-in 1.0V reference
// read the input on analog pin 0:
int sensorValue = analogRead(ADC_BATTERY);
// Convert the analog reading (which goes from 0 - 1023)
float voltage = sensorValue * (battery_voltage / 1023.0);
// print out the value you read:
Serial.print("Voltage: ");
Serial.print(voltage);
Serial.println("V");
float battery_percentage = ((voltage * 100) / battery_voltage);
Serial.print("Batery Percentage: ");
Serial.print(battery_percentage);
Serial.println("%");
analogReference(AR_DEFAULT);
