Reading the position of a flex sensor to set a limit
Ok, I want to read the current position of the flex sensor when the button is pressed and use the coordinates as the limit point. So say you physically bend the flex sensor where you want the limit to be and hit the button. It remembers that position and if it reaches that position or beyond then it beeps the buzzer. I almost have it I just don’t know how to assign the coordinates as a string/array?
See Attached diagram (batt. Is 9v and res. Is 10k)
int flexSensorPin = A0;//analog pin 7= tiny2=A1
const int Piezo = 3; //digital pin 3 = tiny0
const int inPin = 2; // Push Button to set current Bend Status
pinMode (Piezo, OUTPUT);
pinMode(inPin, INPUT); // declare pushbutton as input
int val = 0;
val = digitalRead(inPin)
; int flexSensorReading = analogRead(flexSensorPin);
Serial.println(flexSensorReading);
if (flexSensorReading < 100) {
Serial.println(“Alarm! Set Angle Exceeded”);
digitalWrite(Piezo, HIGH);
delay(100);
digitalWrite(Piezo, LOW);
delay(250);
The logic sounds simple
start of loop()
  if the button is pressed
    read the flex sensor and save the value to a variable
  end if
  if the value is greater than the saved value
    execute the code here
  end if
end of loop()
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Why do you need an array?
Does your code work?
What is the application?
Thanks… Tom… :slight_smile:
What’s with all the underlining ?
Did you intend for some of the text to be links ?
It's a spammer UKHeliBob. For some reason the forum doesn't show links in the normal blue color when they are in underlined text so it makes it not so obvious that they have snuck a bunch of spam links in with the rest of the text that's harvested from posts on this forum.
Ah, I see. We can normally spot a link because it's underlined and blue. In order to hide the spam links they underlined all the text and used color tags to override the normal link blue color.
pert:
Actually you can still see the linked text because it is double underlined, but I have no intention of clicking on them.
const int flexSensorPin = A0;//analog pin 7= tiny2=A1
const int PiezoPin = 3; //digital pin 3 = tiny0
  pinMode (PiezoPin, OUTPUT);
int Limit = 100;  // Made this Global so the value persists.
  int val = digitalRead(inPin);
  if (val)
    // Button is pressed
    Limit = flexSensorReading;
  if (flexSensorReading < Limit)
    Serial.println("Alarm! Set Angle Exceeded");
    digitalWrite(PiezoPin, HIGH);
    delay(100);
    digitalWrite(PiezoPin, LOW);
Been Hacking trying to make this work, I’m hung up on the context of assigning and using integers. At startup I want to read the value of the current position of the flex sensor and use that as a start point. After that the flex sensor will be moved straight again and if flexed to that value or beyond then the buzzer should start. If you want to set a new position then set the flex sensor where you want the limit to be and then press the button and the new parameter is set. This code is hacked as you can see I know I’m just missing something simple… The value in this hacked code is hard set to 100 but thats what I want to make the stored integer.
// int StartValue = flexSensorPin;
  int val = 0;
//  if inPin( HIGH goto Start;
    if(digitalRead(inPin)){
//    LoggedPosition=flexSensorReading;
    delay(100);
  delay(250);
Does you code work as in the post above, to sound buzzer on exceeding threshold?
What do you want to put in the array?
How have you got your button wired?
Thanks.. Tom.. :slight_smile:
Are you SURE you only want to look at the button when the alarm is sounding?!? You will only be able to set the limit to a value lower than the current limit.
    if (digitalRead(inPin)) {
    delay(100);
Look at the sketch I posted to see one way to correct this programming error.
TomGeorge:
I want it to set the value of the current position when the button is pressed or when powered up then use that value as the “boundary” point where if that’s met or exceeded then the alarm sounds and continues to sound until the button is pressed to reset the value or the flex sensor is moved to the “safe” position.
My code is kinda hacked now, not sure things are necessary or even in the right places. Please bear with me, I’m still thinking in basic and q basic. Am new to C++ and as you can see i’m lost. Anyways I have it set to go off greater than 250. That’s the spot where I want the remembered “string” to be the boundary (replaces the 250 with an integer or string). It doesn’t seem like the button even registers at this point.
int LoggedPosition = flexSensorPin;
int val = 0;
  if (flexSensorReading > 250) {
//    if(digitalRead(inPin)){
    delay(100);
  delay(250);
Another approach is to use some sort of mode condition.
loop() {
  if we are in limit setting mode
    do the limit setting loop
    do the normal operation loop
limit_setting_loop() {
  if the "end of mode" button is pressed (released, whatever)
    set mode to normal operation
    if the 'set upper limit' switch is pressed
      record the upper limit
  etc etc
normal_operation_loop() {
  if the "set limits mode" button is pressed (released, whatever)
    set mode to setting limits
    do the normal stuff
johnwasser:
    delay(100);
The alarm works using the code above but I changed it to "if (flexSensorReading.> 250)" because the sensor works better in the other direction. What I want is to make the 250 a string or integer thats the current position of the sensor on power up or pressing the button. So, say you bend it 45 degrees and press the button, the flex sensor is released and it monitors for the flex sensor to reach 45 or beyond and starts alarming.. Then you bend it at say 80 degrees and press the button and it does the same but for 80 degrees.
sierratech:
I want it to set the value of the current position when the button is pressed or when powered up then use that value as the "boundary" point where if that's met or exceeded then the alarm sounds and continues to sound until the button is pressed to reset the value or the flex sensor is moved to the "safe" position.
Hi, you don't have to store your threshold value in an array.
If it is a single number then store it as a single variable.
Tom..
