Reading the USB port from one Arduino to another
Hello Forum
This is my first appearance here.
Matt from Germany, 52 years old.
My very simple question is this:
Is it possible to receive data via the USB port of Arduino Nano #1 ( which sends data every second to its serial port by ordinary code) to the USB port of Arduino #2 which both are connected by a simple 1:1 wired connection?
Any yes or even any no would be welcome :slight_smile:
Thanks in advance,
Matt
Of course this begs the question:
Why are you using two Arduinos?
Hello
It MUST be done over the USB port.
The reason is:
Arduino #1 is already part of an existing ( and working) project. Every second it writes a four character long data to the USB port.
Normally the customer uses his PC to read this value - no problem at all.
Using Arduino #2 would allow the customer to use Arduino #1 without the need of a PC just by applying a small display to Arduino #2.
So again my question: Is it possible?
Cheers,
Matt
Then the answer is no.
The second Arduino can be hooked to the TX pin of the first one, so that all output goes to both PC and second Arduino.
Delta_G:
Hello :slight_smile:
Your answer looks quite good.
But what about the cable?
Does it have to be a special one? ( which I would appreciate )
Thank you for any answer.
