Reading the width of the pulse with Resolution of 1 Microsecond
I want to measure the pulse width with resolution of 1 microsecond. will PulseIn Do that? or Does this Code.
ISR(TIMER1_CAPT_vect){
  if(bit_is_set(TCCR1B,ICES1)){
    // if rising Edge is Detected
    TCNT1 = 0; // make the timer count 0
    TCCR1B ^= _BV(ICES1);
  else {
    captureValue = ICR1;
Which is the Accurate One
Here's how the 1-pin cap sense does close, sub usec timing.
http://playground.arduino.cc/Code/CapacitiveSensor
the critical part, the whole is at the link,
  // Prevent the timer IRQ from disturbing our measurement
  noInterrupts();
  // Make the pin an input with the internal pull-up on
  *ddr &= ~(bitmask);
  *port |= bitmask;
  // Now see how long the pin to get pulled up. This manual unrolling of the loop
  // decreases the number of hardware cycles between each read of the pin,
  // thus increasing sensitivity.
  uint8_t cycles = 17;
       if (*pin & bitmask) { cycles =  0;}
  else if (*pin & bitmask) { cycles =  1;}
  else if (*pin & bitmask) { cycles =  2;}
  else if (*pin & bitmask) { cycles =  3;}
  else if (*pin & bitmask) { cycles =  4;}
  else if (*pin & bitmask) { cycles =  5;}
  else if (*pin & bitmask) { cycles =  6;}
  else if (*pin & bitmask) { cycles =  7;}
  else if (*pin & bitmask) { cycles =  8;}
  else if (*pin & bitmask) { cycles =  9;}
  else if (*pin & bitmask) { cycles = 10;}
  else if (*pin & bitmask) { cycles = 11;}
  else if (*pin & bitmask) { cycles = 12;}
  else if (*pin & bitmask) { cycles = 13;}
  else if (*pin & bitmask) { cycles = 14;}
  else if (*pin & bitmask) { cycles = 15;}
  else if (*pin & bitmask) { cycles = 16;}
  // End of timing-critical section
  interrupts();
Note that micros() returns a value with 4 usec granularity. Interrupts take time to process.
From the looks of it pulseIn will do just that, looks to be quite time consuming tho. I tried to read the pulse width from a RC receiver, to determine what to do in my code based on the length of the pulse. In the end my solution was to use an interrupt to detect a rising edge and another to detect the falling edge. I would then save micros() to a variable on each interrupt then deduct one from the other to give pulse width. This was then checked at the start of each run of my loop.
