Reading Value from Teensy 3.5 to Matlab
Hey all, I'm working with a TeensyDuino 3.5, and I'm trying to read a continously updated byte via Serial to Matlab. This signal is simply a flag that I want to be high under some conditions, and low every other time. I've simplified my code down to just the transmission and reception of Serial data, and I can't figure out what Matlab function I should be using, or what type of transmission I should do in Arduino.
My Arduino Code:
byte val = 0;
unsigned long past;
Serial.begin(9600); //Teensy ignores parameter and runs at 12MB/sec
past = millis();
unsigned long currTime = millis();
Serial.write(val);
if ((currTime - past) > 5000){
// Every 5 seconds change the value of the transmission
past = millis();
val = 1-val;
My Matlab Code:
% Serial Read debug
clear;
coms = instrfind;
if ~isempty(coms)
fclose(coms);
end
SerialID = serial('COM13', 'BaudRate', 9600);
fopen(SerialID);
test = fread(SerialID, 512);
pause(6);
test_new = fread(SerialID, 512);
pause(6);
test_old = fread(SerialID, 512);
pause(6)
test_new_new = fread(SerialID, 512);
%fclose(SerialID);
Each fread returns the same array. How can I fix this?
Matlab probably works like other programming languages, you would need to open serial port and read one byte at a time.
