Reading values and changing them into HEX
First I read the characters that I receive.
The characters are either A to F and 0 to 9.
An example message would be: A1 B2 C3 etc.
the goal is to get A1 (161, decimal) in Decode[0] and to print it.
The problem that i am facing right now is that my code loops through it and prints it step by step.
I want it to print when its done.
Also i want to use cases where i check certain places in the array to know what my code should do.
In the attachements you can see my serial monitor and evuentally it will print the final message(A1 B2 C3) this is to show middle part that i dont want to print.
unsigned char myData[50];
unsigned char Decode[50];
int i = 0;
char x;
ontvangen();
void ontvangen () {
byte n = Serial.available();
if (n != 0)
x = Serial.read();
if ((x >= 'A') && (x <= 'F')) //A to F
myData = x - 55;
  • i++;*
  • if ((x >= 'a') && (x <= 'f')) //a to f*
    _ myData = x - 87;_
    * i++;*
    * if ((x >= '0') && (x <= '9')) // 0 to 9*
    _ myData = x - 48;
    * i++;
    unsigned char temp = 0;
    char k = 0;
    for (char j = 0; j <= sizeof(myData); j++) {
    if (j % 2 == 0) {
    temp = myData[j] * 16;
    else {
    Decode[k] = myData[j] + temp;
    k++;
    for (char h = 0; h <= 50; h++) {
    Serial.println(Decode, HEX);
    }_
Get rid of the italics and get back to us.
you may be interested in the following. it deals with simple commands across the serial interface. you can modify it to read hex instead of decimal values
// pcRead - debugging using serial monitor
const char version [] = "PcRead 200416a";
int debug = 0;
// toggle output bit
void
pinToggle (
    int pin)
    static int  bits = 0;
    int     bit = 1 << pin;
    if (debug)  {
        Serial.print ("pinToggle: ");
        Serial.println (pin);
    if (bits & bit)  {
        digitalWrite (pin, LOW);
        bits &= ~bit;
    else {
        digitalWrite (pin, HIGH);
        bits |= bit;
int
readString (
    char *s,
    int   maxChar )
    int  n = 0;
    Serial.print ("> ");
    do {
        if (Serial.available()) {
            int c    = Serial.read ();
            if ('\n' == c)
            s [n++] = c;
            if (maxChar == n)
    } while (true);
    return n;
// process single character commands from the PC
#define MAX_CHAR  10
char s [MAX_CHAR] = {};
int  analogPin = 0;
void
pcRead (void)
    static int  val = 13;
        switch (c)  {
        case '0':
        case '1':
        case '2':
        case '3':
        case '4':
        case '5':
        case '6':
        case '7':
        case '8':
        case '9':
            val = c - '0' + (10 * val);
        case 'A':
            analogPin = val;
            Serial.print   ("analogPin = ");
            Serial.println (val);
            val = 0;
        case 'D':
            debug ^= 1;
        case 'I':
            pinMode (val, INPUT);
            Serial.print   ("pinMode ");
            Serial.print   (val);
            Serial.println (" INPUT");
            val = 0;
        case 'O':
            pinMode (val, OUTPUT);
            Serial.print   (val);
            Serial.println (" OUTPUT");
            val = 0;
        case 'P':
            pinMode (val, INPUT_PULLUP);
            Serial.print   (val);
            Serial.println (" INPUT_PULLUP");
            val = 0;
        case 'a':
            Serial.print   ("analogRead: ");
            Serial.println (analogRead (val));
            val = 0;
        case 'c':
            digitalWrite (val, LOW);
            Serial.print   ("digitalWrite: LOW  ");
            val = 0;
        case 'p':
#if !defined(ARDUINO_ARCH_ESP32)
            analogWrite (analogPin, val);
            Serial.print   ("analogWrite: pin ");
            Serial.print   (analogPin);
            Serial.print   (", ");
            val = 0;
#endif
        case 'r':
            Serial.print   ("digitalRead: pin ");
            Serial.print   (val);
            Serial.println (digitalRead (val));
            val = 0;
        case 's':
            digitalWrite (val, HIGH);
            Serial.print   ("digitalWrite: HIGH ");
            val = 0;
        case 't':
            Serial.print   ("pinToggle ");
            pinToggle (val);
            val = 0;
        case 'v':
            Serial.print ("\nversion: ");
            Serial.println (version);
        case '\n':          // ignore
        case '"':
            while ('\n' != Serial.read ())     // discard linefeed
            readString (s, MAX_CHAR-1);
            Serial.println (s);
        case '?':
            Serial.println ("\npcRead:\n");
            Serial.println ("    [0-9] append to #");
            Serial.println ("    A # - set analog pin #");
            Serial.println ("    D # - set debug to #");
            Serial.println ("    I # - set pin # to INPUT");
            Serial.println ("    O # - set pin # to OUTPUT");
            Serial.println ("    P # - set pin # to INPUT_PULLUP");
            Serial.println ("    a # - analogRead (pin #)");
            Serial.println ("    c # - digitalWrite (pin #, LOW)");
            Serial.println ("    p # -- analogWrite (analogPin, #)");
            Serial.println ("    r # - digitalRead (pin #)");
            Serial.println ("    s   - digitalWrite (pin #, HIGH)");
            Serial.println ("    t   -- toggle pin # output");
            Serial.println ("    v   - print version");
            Serial.println ("    \"   - read string");
            Serial.println ("    ?   - list of commands");
        default:
            Serial.print ("unknown char ");
            Serial.println (c,HEX);
void
loop (void)
    pcRead ();
void
setup (void)
#if defined(ARDUINO_ARCH_ESP32)
    Serial.println ("esp32");
#endif
