Reading vehicle speed sensor with interrupts not working
Hey guys i am trying to read the vehicle speed sensor in my truck ( 14V 8000 pulses per mile). I put the signal through a resistor divider ( 2.2k and 1k) and read 3.23V with truck stationary and around 1.62V with the truck moving. The problem I am having is that the interrupt function in my code doesnt seem to be working. Can anyone see where the problem is?
Thanks!
#include <PID_v1.h>
#include <PWM.h>
#include <SPI.h>
#include <LiquidCrystal.h>
int32_t frequency = 167; //frequency (in Hz)
const int numReadings= 3;
//exhaust pressure sensor
int ebp_readings[numReadings];
int ebp_index = 0;
float ebp_total = 0;
float ebp_average = 0;
const int ebp = A0;
//throttle position sensor
int tps_readings[numReadings];
int tps_index = 0;
float tps_total = 0;
float tps_average = 0;
const int tps = A1;
int tps_counter = 0;
//vehicle speed sensor
unsigned long current_time2;
unsigned long previous_time2 = 0;
volatile int vss_counter = 0;
unsigned long vss_freq = 0;
//Relay
int relay = 12;
//PWM pin
int pwmOut = 9;
// LCD timer
unsigned long current_time1;
unsigned long previous_time1 = 0;
//pid information
double Setpoint, Input, pidOutput;
PID myPID(&Input, &pidOutput, &Setpoint,1,0,0, DIRECT);
// initialize lcd
LiquidCrystal lcd (8, 7, 6, 5, 4, 3);
  pinMode(relay, OUTPUT);
  pinMode(pwmOut, OUTPUT);
  attachInterrupt(0, vspeed, FALLING);
  for (int ebp_thisReading = 0; ebp_thisReading < numReadings; ebp_thisReading++)
    ebp_readings[ebp_thisReading] = 0;
  for (int tps_thisReading = 0; tps_thisReading < numReadings; tps_thisReading++)
    tps_readings[tps_thisReading] = 0;
  //initialize all timers except for 0, to save time keeping functions
  InitTimersSafe();
  //sets the frequency for pwmOut pin 9
  bool success = SetPinFrequencySafe(pwmOut, frequency);  //change to pwmOut after testing
  //if the pin frequency was set successfully, turn pin 13 on
  if(success) {
  //initialize PID variables
  Input = ebp_average;
  Setpoint = 253;  //test value = 10 psig
  myPID.SetOutputLimits(38, 115);
  //turn the PID on
  myPID.SetMode(AUTOMATIC);
  // lcd setup
  lcd.begin(16, 2);
  lcd.clear();
  lcd.print("BRAKE%:");
  lcd.setCursor(0,1);
  lcd.print("EBP:");
void vspeed(){
  detachInterrupt(0);
  ++vss_counter;
   current_time1 = millis();
  // LCD Display
  if(current_time1 - previous_time1 > 400){
    previous_time1 = current_time1;
  //print exhaust pressure sensor measurement
  lcd.setCursor(4, 1);
  lcd.print("   ");
  lcd.print(((ebp_average * 0.00488 * 19) - 13), 0);
  lcd.setCursor(12,0);
  lcd.print("     ");
  lcd.print(vss_freq);
  lcd.setCursor(12,1);
  lcd.print("         ");
  lcd.print(tps_counter);
  ebp_total= ebp_total - ebp_readings[ebp_index];
  ebp_readings[ebp_index] = analogRead(ebp);
  ebp_total= ebp_total + ebp_readings[ebp_index];
  ebp_index = ebp_index + 1;
  if (ebp_index >= numReadings)
    ebp_index = 0;
  ebp_average = ebp_total / numReadings;
  tps_total= tps_total - tps_readings[tps_index];
  tps_readings[tps_index] = analogRead(tps);
  tps_total= tps_total + tps_readings[tps_index];
  tps_index = tps_index + 1;
  if (tps_index >= numReadings)
    tps_index = 0;
  tps_average = tps_total / numReadings;
  current_time2 = millis();
    if(current_time2 - previous_time2 >= 1000) {
    vss_freq = vss_counter;
    vss_counter = 0;
    previous_time2 = current_time2;
  //tps counter
  if(tps_average <=81){
    ++tps_counter;
  else{
    tps_counter = 0;
  //Output
  if(tps_counter >= 15){
    digitalWrite(relay, HIGH);
    myPID.Compute();
    pwmWrite(pwmOut, pidOutput);
    //print pidoutput
    lcd.setCursor(7, 0);
    lcd.print("   ");
    lcd.setCursor(7,0);
    lcd.print(((pidOutput / 255) * 100) * 2, 0);
    else{
    pwmWrite(pwmOut, 0);
    digitalWrite(relay, LOW);
    lcd.setCursor(7,0);
    lcd.print("   ");
    lcd.setCursor(7,0);
    lcd.print("OFF");
void vspeed(){
  detachInterrupt(0);
  ++vss_counter;
That looks suspicious to me. Why are you detaching the interrupt? Would seem to count to 1 then never increment again?
Plus I think the vspeed() function must be placed/declared outside the setup() and loop() functions?
Lefty
Thanks for looking it over lefty. I removed the detached interrupt and still no luck. I made a code that just does the interrupt and it works as it should. hmm... i dont understand..
#include <SPI.h>
#include <PWM.h>
const int pwmOut = 9;
const int vssIn = 2;
// initialize lcd
void setup(){
  pinMode(vssIn, INPUT);
  digitalWrite(vssIn, HIGH);
  lcd.begin(16, 2);
  InitTimersSafe();
  if(success) {
    pwmWrite(pwmOut, 200);
void vspeed(){
  ++vss_counter;
void loop(){
    vss_counter = 0;
  lcd.print("     ");
What isn't working ?
I got it working!!!! Thanks guys!
Hey Mitch. You said you got your interrupt to work. Does it fire at both 3.23V and at 1.62V? Why are you getting a reading when the truck isn't moving?
I'm working on a project of my own using the vss....which I believe is an ABS sensor in my 2006 Toyota Sienna. It is a purple wire in a cluster way up behind the steering column. It gives me a reading of 2.35V on my multimeter. I'm assuming it is an analog sine wave, but I don't have an o-scope. I was thinking I'd have to step up the voltage to 5v for the interrupt to fire every time the vss/abs ticks.
I've read about it online, but I really don't know much about the vss/abs. Not even sure if I'm talking about it correctly. Anyone have experience with this? Mitch, how about you?
