hummm.... compiles okay, but get a 'bad reading' and no antenna ports selected as i change the input voltages.
the bottom LCD prints out fine. The "DO NOT tramit' works when pin 4 is low and my voltage test works when pin 4 is low
but thats about it
but thats about it
I've been thinking in an analog world.
what if?
Is is possible to do away with reading voltages and using a rotary encoder to simply select the antenna I want, then write to a pin and let a optocoupler and relay do the heavy lifting?
I dont have a clue if that is even possible let alone know how to do it
mike
let me fire up a board and get some serial prints going to see whats wrong its probably a mistake I have made.
don't see a problem. Run this for me and tell me what it says. It should say bad then the numbers that are being used
theres some code in there that by passes the switch and other junk just ignore that for now
/*/remote switch display
vers 3.2 26 August 2017
Voltage read on A1 from antenna remote
Fault alarm pin 4
Test switch on pin 9
// Voltage read on A1 from antenna remote
//#include <LiquidCrystal.h>
//LiquidCrystal lcd(8,9,10,11,12,13); DONT NEED THIS NOW WITH I2C LCD
#include <Wire.h>
#include <LCD.h>
#include <LiquidCrystal_I2C.h> // F Malpartida's NewLiquidCrystal library
#define I2C_ADDR 0x27 // Define I2C Address for controller
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
#define BACKLIGHT 3
#define fault 4 //THIS IS THE PIN THAT LOOKS FOR THE fault LED from switch controller. H = ok L = fault
#define test 9 // switch to turn on voltage readings for setting display
LiquidCrystal_I2C lcd(I2C_ADDR, En_pin, Rw_pin, Rs_pin, D4_pin, D5_pin, D6_pin, D7_pin);
int input2;
int input ;
int antenna;
int radios;
int testPin = 9; //digital pin 9 for switch to show volts on display
int antennaNumber = 0;
lcd.setBacklightPin(3, POSITIVE);
lcd.begin(16, 2);
// Serial.begin(9600);
lcd.clear(); //clears any junk on the screen
// delay(2000); //wait 2 seconds
lcd.print(" Antenna Switch"); //a quick splash
// delay(4000); //take a look for four seconds
pinMode(4, INPUT_PULLUP); // Fault input on digital pin 4
pinMode(testPin, INPUT_PULLUP); //select for voltage readings on LCD
//input = analogRead(A1); //this is the input for the antenna relays
input2 = analogRead(A2); //input for the transceivers
//antenna = (input / 129) + 1;
radios = (input2 / 129) + 1;
show();
//****Functions****
void show() {
static byte prevtestButton;//done this so i can see a state change to clear lcd
static byte prevfaultButton;//done this so i can see a state change to clear lcd
byte testButton = digitalRead(testPin);//done this so i can see a state change to clear lcd
byte faultButton = digitalRead(fault);//done this so i can see a state change to clear lcd
if (prevtestButton != testButton || prevfaultButton != faultButton) {
lcd.clear();//got to work out how to deal with this to stop screen flicker
prevtestButton = testButton;
prevfaultButton = faultButton;
byte testing = 1;
//if (testButton == LOW) { //when pin is low, the Display will show AD voltage on LCD
if (testing == 1) {
lcd.setCursor(0, 0); //returns cursor to first line
lcd.print("#"); //only way I know of to get both the voltage and antenna port on the LCD
input = analogRead(A1); //wake pin
// int serialtest= 995;
// antennaNumber = map(serialtest, 0, 1024, 1, 9);//read pin
// Serial.print("antennaNumber ");
// Serial.println(antennaNumber);
antennaNumber = map(analogRead(A1), 0, 1024, 1, 9);//read pin
lcd.print(antennaNumber); //was to put these IF statements here or the line blinked.
printAntenna(antennaNumber);
lcd.setCursor(0, 1);
lcd.print(input / 204.6);
lcd.setCursor(5, 1);
lcd.print(" volts input");
// delay(500); // reduce flicker
} else if (faultButton == LOW) { //Fault and test both active?
//this tests to see if the antenna switch has a fault
lcd.setCursor(0, 0); //sets cursor to second line
lcd.print("SWITCH FAULT! "); //prints to lcd that something is wrong
lcd.print("Do NOT transmit!");
} else {//test pin and fault pin are high to get here
//this selects the antenna and displays the results on the LCD
lcd.print("#");
lcd.print(antennaNumber); //prints out the number of the switch
//Let's select a radio by reading the voltage on analog pin 2
lcd.setCursor(0, 1); //places this info on the second line
// lets show what radios are connected to the other switch
lcd.print("#");
lcd.print(radios);
if (radios == 1)lcd.print(F("TenTec OMNI 7 "));//made same lenght to over write
if (radios == 2)lcd.print(F(" Yaesu FT-450D "));
if (radios == 3)lcd.print(F(" TenTec Jupiter"));
if (radios == 4)lcd.print(F(" TenTec Omni V "));
if (radios == 5)lcd.print(F(" TenTec Omni C "));
if (radios == 6)lcd.print(F(" Drake TR4CW "));
if (radios == 7)lcd.print(F(" Drake TR-5 "));
if (radios == 8)lcd.print(F(" Yaesu FT-1200 "));
// delay(200);//Reduce flicker
void printAntenna(int show) {
switch (show) {
case 1:
lcd.print(F(" Vertical "));//made same lenght to over write
case 2:
lcd.print(F(" 40 Meter DP "));
case 3:
lcd.print(F(" (Yagi) "));
case 4:
lcd.print(F(" (Loop) "));
case 5:
lcd.print(F(" (6 meter DP)"));
case 6:
lcd.print(F(" (Parabolic) "));
case 7:
lcd.print(F(" (Beverage) "));
// Serial.println("ok");
case 8:
lcd.print(F(" (Dummy load)"));
default:
lcd.print(F("bad "));
lcd.print(input);
lcd.print(" ");
lcd.print(show);
ok I found what I had screwed up
carn't read a pin with in a "if" then expect a different "if" to read the same pin
sry I was playing in your code so I might have made a mess but this should show that the idea works
Fault alarm pin 4
#include <Wire.h>
#include <LCD.h>
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
#define BACKLIGHT 3
int input2;
int input ;
int antenna;
int radios;
lcd.begin(16, 2);
show();
//****Functions****
void show() {
// reduce flicker
lcd.print("#");
lcd.print("#");
lcd.print(radios);
void printAntenna(int antDisplay) {
switch (antDisplay) {
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
case 8:
default:
lcd.print(input);
lcd.print(" ");
lcd.print(antDisplay);
