Reading voltage from the Arduino board itself
Hi all,
Just wondering if it is possible to read the current system voltage of the board itself. Are there any libraries for this? I'm experimenting with a Arduino Nano at the moment.
Best regards torix
Yes you can. Assuming you are using the default 5V analog reference, you can get the ADC to read the internal bandgap voltage reference. Looking at the code for analogRead, I believe that on the atmega328-based boards, you can so this by calling analogRead(28). The reading you get will be 1024 * (Vbg/Vcc) where Vbg is a fixed voltage for any particular chip, nominally 1.1V but possibly anywhere between 1.0V and 1.2V. Since Vbg is fixed, you can calculate Vcc from the reading.
I don´t know if it could help, but follow this topic: http://forum.arduino.cc/index.php/topic,15629.0.html
madepablo: I don´t know if it could help, but follow this topic: http://forum.arduino.cc/index.php/topic,15629.0.html
The "tinkerkit secret voltmeter" linked to in that thread uses the same technique that I described, but using direct access to the ADC instead of analogRead.
Hi dc42, I didn´t know. I am newby and i was only trying to contribute... In any case, may be by the use of this alternative method you could save one pin. I don´t know, as i said, i do not have so much experience on electronics ;-) Cheers
dc42: Yes you can. Assuming you are using the default 5V analog reference, you can get the ADC to read the internal bandgap voltage reference. Looking at the code for analogRead, I believe that on the atmega328-based boards, you can so this by calling analogRead(28). The reading you get will be 1024 * (Vbg/Vcc) where Vbg is a fixed voltage for any particular chip, nominally 1.1V but possibly anywhere between 1.0V and 1.2V. Since Vbg is fixed, you can calculate Vcc from the reading.
Thank you. It is interesting to know that the "pin" 28 is for the internal bandgap. Could you tell how to find the code for analogRead()?
madepablo: Hi dc42, I didn´t know. I am newby and i was only trying to contribute...
No worries, I wasn't trying to belittle your valuable contribution, just pointing out that the underlying mechanism was the same.
LQVE: Thank you. It is interesting to know that the "pin" 28 is for the internal bandgap. Could you tell how to find the code for analogRead()?
On my system, it's in C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\wiring-analog.c.
