I have decades of experience with electronics and microcontrollers but this is my first post in these forums. Thanks in advance for your assistance - I hope to be able to return the favor at some point.
I have a project using a 'Genuino' Mega 2560, Adafruit datalogging shield, and the recommended Adafruit library.
I want to repeat the following tasks:
Open an SD file, write some raw sensor data to it, then close that file.
Open an SD file with a different name, write some averaged sensor data to it, then close that file.
The following code to accomplish task #1 works fine:
//SDCardSingleFile
//SD card library and defines.
#include <SD.h>
#include <SPI.h>
const int chipSelect = 10;
String outFileName;
String outLine;
// SETUP
// Initialize serial port.
Serial.println("Setup");
//Set up DS memory card.
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
while (1);
Serial.println("card initialized.");
outFileName="TESTFILE";
Serial.println("Open file: "+outFileName+".RAW");
File dataFile = SD.open(outFileName+".RAW", FILE_WRITE);
outLine="Here is some raw data.";
Serial.println("Writing raw data: "+outLine);
// if the file is available, write to it:
if (dataFile) {
dataFile.println(outLine);
// if the file isn't open, pop up an error:
else {
Serial.println("error writing to SD");
Serial.println("Close raw file.");
dataFile.close();
delay(5000);
The following code to attempt #1 and then #2 gives me a compile error "redeclaration of 'SDLib::File dataFile" at the point I try to open the second file.
//SDCardMultiFile
#include <SD.h>
#include <SPI.h>
String outFileName;
String outLine;
// SETUP
while (1);
if (dataFile) {
else {
dataFile.close();
Serial.println("Open file: "+outFileName+".TXT");
File dataFile = SD.open(outFileName+".TXT", FILE_WRITE);
outLine="Here is some processed data.";
Serial.println("Writing processed data: "+outLine);
if (dataFile) {
else {
Serial.println("Close txt file.");
dataFile.close();
delay(5000);
If I change the second declaration to open dataFile2, that works, but concerns me because the last thing I need to do is:
- Accept a filename over the serial port, then open that file if it exists and transmit the contents over the serial port. I want to be able to make this happen an arbitrary number of times, over and over.
Can't I use the same file 'handle' (is that the term?) to open different files for different purposes, some read, some write, so long as I close one file before opening another? If I have to use different file 'handles' (dataFile, dataFile2, and so forth) what happens when I get to task 3 and want to send a file over the serial port, then open a different one?
I haven't seen this exact issue addressed anywhere in this forum or on the web. Hopefully I didn't miss something obvious, but if that happened please be kind.
Thanks,
Tom
"Computers do what you tell them to do, not what you want them to do." - Norman E. Gibbs, 1974.
