Reading wrong chars from EEPROM
I experience some strange behaviour when reading data from the eeprom.
My function "print_string_from_eeprom(start_address)" reads characters from the eeprom and stores them in a buffer until the NULL character is found. Then the buffer is printed.
When the Arduino Uno reads and prints the characters one byte at a time, the output is correct
" abcdef hijklmn".
But when I use my function two errors occur:
  1. Some characters are missing / skipped.
  2. The 0 is not always recognized.
#include <EEPROM.h>
void print_string_from_eeprom(int initial_start_address){
  //continue reading from initial_start_address until '\0' or end of memory
  char current_char;
  bool continue_read = 1;
  int current_address = initial_start_address;
  while(continue_read){
    const uint8_t buffer_size = 20;
    char buffer[buffer_size] = {0};
    for(int i = 0; i< buffer_size; i++){
      current_address = current_address + i;
      //Abort if out of memory area
      if (current_address == EEPROM.length()){
        Serial.print("OUT OF BOUND");
        continue_read = 0;
      current_char = EEPROM.read(current_address);
      delay(100);
      if (current_char == NULL) {
        continue_read = 0;
        //Serial.print("NULL");
      buffer[i] = current_char;
    Serial.print(">");
    Serial.print(buffer);Serial.print("<");
void setup(){
  EEPROM.update(0, 0);
  EEPROM.update(1, 0);
  EEPROM.update(2, 'a');
  EEPROM.update(3, 'b');
  EEPROM.update(4, 'c');
  EEPROM.update(5, 'd');
  EEPROM.update(6, 'e');
  EEPROM.update(7, 'f');
  EEPROM.update(8, 0);
  EEPROM.update(9, 'h');
  EEPROM.update(10, 'i');
  EEPROM.update(11, 'j');
  EEPROM.update(12, 'k');
  EEPROM.update(13, 'l');
  EEPROM.update(14, 'm');
  EEPROM.update(15, 'n');
  EEPROM.update(16, NULL);
   for (int i = 0; i<17; i++){
    Serial.print((char)EEPROM[i]); //gives correct output " abcdef hijklmn"
  for (int i = 0; i<12; i++){
    Serial.print("from "); Serial.print(i); Serial.print(": ");
    print_string_from_eeprom(i); //here the wrong output occurs
void loop(){}
The bytewise read / print command gives
abcdef hijklmn < //correct
But my function (starting at address ... returns):
from 0: >< //correct
from 1: >< //correct
from 2: >abd< // should be "abcdef"
from 3: >bcehl< // should be "bcdef"
from 4: >cdfim< //should be "cdef"
from 5: >de< // should be "def"
from 6: >efhk< // should be "ef"
from 7: >f< //correct
from 8: >< //correct
from 9: >hik< /should be "hijklmn"
from 10: >ijl< //should be "ijklmn"
from 11: >jkm< //should be "jklmn"
I have been looking over my code again and again, without spotting the flaw.
Can someone please confirm this output and check the code?
You are using a strange advance technique, try mine
//    current_address = current_address + i;
      current_address++;
Look at
Current address is not incremented by 1 but with i
Change it to
  char current_char;
    //you can hold 19 chars, last should me 0
    for(byte i = 0 ; i< buffer_size - 1; i++){
      //current_address = current_address + i;
      if (initial_start_address + i >= EEPROM.length()){
        continue_read = 0;
        //terminate string!
        buffer[i] = 0;
      current_char = EEPROM.read(initial_start_address + i);
      //delay(100); //why delay.... :(
        continue_read = 0;
        //terminate string!
        buffer[i] = 0;
    Serial.print(">");
    Serial.print("<");
Made some more changes then that. Please note them :wink: Because you can overshoot the array...
Also, if you want a space, don't use 0. 0 is the end of the array (aka NULL). if you want a space use ' ' or 32 (ascii space).
You would have to move the increment to the bottom of the loop, or add it to the for
    for(int i = 0; i< buffer_size; i++, current_address++){
        continue_read = 0;
      delay(100);
        continue_read = 0;
I am so blind... Maybe I should take a break.
Thank you guys for pointing out the obvious!
