Hi!
Im trying to turn 4 LEDs on when pressing 4 buttons. The thing is that the LEDs and buttons is separated. They are connected to 2 different Arduino boards. They connect using wireless RF links.
I managed to make the two boards communicated perfectly. When pressing one of the buttons on the first Arduino, the other Arduino receives what it should. The LEDs just aren’t lighting up.
Transmitter code:
#include <VirtualWire.h>
const char *red = "r";
const char *green = "g";
const char *yellow = "y";
const char *green2 = "G";
const int greenButton = 2;
const int yellowButton = 3;
const int redButton = 4;
const int greenButton2 = 5;
Serial.println("setup");
//Button pin setup
pinMode(greenButton, INPUT);
pinMode(yellowButton, INPUT);
pinMode(redButton, INPUT);
pinMode(greenButton2, INPUT);
// Tranmitter setup
vw_setup(4000);
vw_set_tx_pin(7);
if (digitalRead(redButton) == HIGH){
digitalWrite(13, HIGH);
vw_send((byte *)red, strlen(red));
vw_wait_tx();
delay(200);
else if (digitalRead(greenButton) == HIGH) {
vw_send((byte *)green, strlen(green));
vw_wait_tx();
delay(200);
else if (digitalRead(yellowButton) == HIGH){
vw_send((byte *)yellow, strlen(yellow));
vw_wait_tx();
delay(200);
else if (digitalRead(greenButton2) == HIGH){
vw_send((byte *)green2, strlen(green2));
vw_wait_tx();
delay(200);
else{
digitalWrite(13, LOW);
Receiver code:
long msg;
int greenLED = 8;
int yellowLED = 9;
int redLED = 10;
int greenLED2 = 11;
Serial.println("Setup");
pinMode(greenLED, OUTPUT);
pinMode(yellowLED, OUTPUT);
pinMode(redLED, OUTPUT);
pinMode(greenLED2, OUTPUT);
digitalWrite(greenLED, LOW);
digitalWrite(yellowLED, LOW);
digitalWrite(redLED, LOW);
digitalWrite(greenLED2, LOW);
vw_set_rx_pin(7);
vw_setup(4000);
vw_rx_start();
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen))
int i;
for (i = 0; i < buflen; i++)
char c = (buf[i]);
Serial.print(c);
Serial.print("");
Serial.println("");
if (Serial.available() > 0){
msg = Serial.read();
if (msg == 'g'){
digitalWrite(greenLED, HIGH);
if (msg =='r'){
digitalWrite(redLED, HIGH);
if (msg == 'y'){
digitalWrite(yellowLED, HIGH);
if (msg == 'G'){
digitalWrite(greenLED2, HIGH);
I can read in the Serial Monitor that the receiving Arduino is receiving what i should (y, g, r, G). Also, when I manually send these characters to the serial monitor the LEDs light up. But when pressing the buttons they won’t?
